Questions Of The Week 11/16/2025
Welcome To Questions of the Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submitting your Mailing address for shipping.
Choose your prize from the following list:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
1) You are inspecting an older home which has replacement windows and new vinyl siding. The new siding is backed up with rigid foam insulation that covers the service entrance cable from the weather head to the meter. You should report that this is
a) Acceptable because the siding is a non-conducting type.
b) An improper installation that should be corrected.
c) A benefit because additional protection is provided to the service entrance cable.
d) Acceptable, provided the drip loops at the service entrance head are left exposed.
2) You inspect a wood framed cantilevered balcony off a second-story bedroom. You find significant wood deterioration (at least one-half member depth) of all cantilever joists at the bearing point of the house. You should
a) Notify the occupants of the significant hazard, advise immediate repair to both the occupant and client in the report.
b) Note the significant hazard and recommend immediate repair, by licensed professional, in your report.
c) Refer the wood deterioration to a structural pest control operator for professional opinion.
d) Recommend sistering existing framing members to increase strength, prior to further use.
3) When looking at the exterior wall of a sixty year old brick masonry house with a gable roof, you notice a horizontal crack in the mortar and outward brick displacement along the gutter edge of the roof. The displacement is greatest at the center of the top three courses of brick. This condition is MOST likely caused by
a) Excessive sand in the mortar mix.
b) Defective brick bonding.
c) Improper ceiling joist installation.
d) Differential settlement.
4) The reason a dielectric union would be used in plumbing distribution pipes is to
a) Ensure that the grounding conductor has a secure connection.
b) Separate two dissimilar metals to prevent corrosion.
c) Isolate any electric wires touching the supply pipes.
d) Bond the hot and cold water pipes.
5) On a hillside house with foundation drain systems,
a) Rock-filled foundation drains are not allowed on the interior side of the foundation.
b) The roof drains should connect directly to the foundation drains and have cleanouts.
c) All foundation drain systems must be in perforated plastic piping extending to daylight.
d) The foundation drain systems collect water passing laterally through the slope.
Great questions, Peter, :thinking:
Agreed. :slight_smile:
Great QOTW, Peter! :+1:
Bump
I agree with Scott and Junior . great questions and I win again….
Great QOTW Peter!
  1. b
  2. a
  3. c
  4. b
  5. c
The winner of this installment of QOTW is David Freund !!
David got a 4 out of 5 correct. WTG David !!
Congrats on the win, David! :+1:
WTG, David. :wink:
Thanks Peter! I love being #1 out of 1…my confidence is soaring! :rofl:
Which one did I get wrong?
Congrats David!
Congratulations, David @dfreund !! :collision: :heavy_dollar_sign: :collision: :money_bag: :collision:
You know how to claim your prize.
And, you are listed here:
iNACHI Awards Chapter - InterNACHI®
Which answer did he get wrong?
@pgiannino ?
My guess would be c or d.
#5 I believe should be d)
Agree…
all of the above !……congratulations David…..
I think #3 should be “d” also.
