Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
https://certifiedmasterinspector.org/video-contest
This week’s questions deal with trusses. When answering think only of typical roof trusses for a single family residential structure. That helps keep the thinking and answers a little simpler.
Good luck!!
Q1 – This is a two part question.
What geometric shape is used as the basic concept for trusses?
Why is this shape used as the main concept for building a truss?
Q2 – On a typical truss what is the name of the point where the top and bottom chords meet?
Q3 – What are the four components of a typical truss?
Q4 – Which truss style is comprised of only one web member?
Q5 - When trusses are manufactured at large manufacturing operations what two methods are used to secure the truss plates to the truss members?
Q6 - When a truss is designed to span the entire roof from one side to the other but there is a desire to have room for mechanical equipment, a finished attic area, or other storage type area then what truss design is typically used.
Q7 – The following is a multi-part question.
Permanent bracing/lateral support is required between trusses. What three planes are required to be braced?
What are some of the materials acceptable for bracing materials in each of the planes?
Q8 – The following is a multi-part question.
Where are truss plates installed?
Are truss plates suppose to be installed in a specific orientation to the wood member it is securing?
Can truss plates overhang a wood member?
Is there any allowable tolerance for damage to truss plates and/or bending of truss plates?
They were a lot of fun and I did learn a lot. It’s some of that the more you know the more you find you don’t know.
