Questions Of The Week 8/18/2024
Welcome To Questions of the Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
1) Which single-ply membrane is compatible with asphalt?
a) PVC
b) Mod bit
c) Polystyrene
d) EPDM
e) Plastic
2) A water stain on a ceiling below a flat roof does not necessarily indicate a leak immediately above because
a) The gravel redirects the water after it penetrates a membrane
b) Water can travel between the plies of the roof before emerging on the interior
c) A flood coat of asphalt is often applied to the roof sheathing below the
membrane, which will redirect the water
d) Vapor retarders may carry water some distance horizontally before it leaks
through
e) Both (b) and (d)
3) Which of the following statements is true?
a) With roll roofing, the flashings are often also made of roll roofing.
b) Modified bitumen is more flexible than roll roofing.
c) Roll roofing is another name for modified bitumen.
d) Roll roofing is more expensive than mod bit.
e) Both (a) and (d) are true.
4) A standing seam roof is
a) A wood roof
b) An asphalt shingle roof
c) A gravel roof
d) A metal roof
e) A slate roof
5) Which of the following statements is true of a modified bitumen roof?
a) The seams are spaced every twelve inches and the surface has a rubbery
feel
b) There is evidence of bleed-out of asphalt at the seams and the seams are
spaced every three feet
c) The surface feels like a vinyl liner of a swimming pool and there is evidence
of solvent at the seams
d) There are no exposed nails
e) Both (b) and (d) are true
1 b
2 e
3 b
4 d
5 b
Nice questions Peter. Thanks for taking time to do QOTW.
  1. B
  2. E
  3. A
  4. D
  5. E
Music answer: yay no music question!
For 3 did you mean long term cost or first install cost :slight_smile:
JERK brice
Great questions, Peter, :thinking:
Fine job with the questions, Peter. :boom: :heavy_dollar_sign: :gift: :red_gift_envelope: :boom:
We appreciate you doing them! :slightly_smiling_face:
Great QOTW, Peter! :wink: :+1:
great Job Peter, I Think Marc has the answer…
Great QOTW, Peter!! :+1:
Those questions are making my brain hurt. :laughing: :thinking:
There are no winners to this installment of Question Of The Week.
very interesting, no idea what topic this is covering.
The topic is roofing, Aidan. :man_shrugging:
1 B
2 E
3 B
4 D
5 E
Good question!
Hi Tony & welcome!
This set of questions is closed out - over.
Why don’t you check in sometime tomorrow & there will be new set for you to answer.
Hope you see you.
So what answers would have made for winners (and chicken dinners)?
