Welcome To Questions of The Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
If you used a multimeter to measure the current in a 3000W electric water heater that uses both of the ungrounded (“hot”) service conductors, it would read -
a) 25A
b) 240V
c) 12.5A
d) 120V
e) 1500A -
If electricity costs $0.10 per kWh, how much does it cost to run a 120V whirlpool bath which draws 5A for ½ hour?
a) 6 cents
b) $6.00
c) 3 cents
d) $3.00
e) 30 cents -
Four service entrance conductors indicates -
a) A 240V service
b) A three-phase service
c) A 120V service
d) A 400A service
e) A 240V service supported by a guy -
In a distribution panel, a black wire and a red wire are connected to separate breakers that are four breakers apart, on the same bus bar. Both wires are part of the same cable. The neutral from the cable connects to the neutral bus. The potential problem with this arrangement is -
a) The 240V appliance may not operate properly
b) Breakers may not be linked
c) The neutral wire may overheat
d) All of the above
e) There is no problem, or not enough information to decide -
Which of the following is not a cause of a loose or damaged breaker?
a) Manufacturing defect
b) Undersized wire
c) Repeated use
d) Rough handling
e) Wear and tear
Bonus Question : When is it possible that the opposing pitcher pitched a no hitter and no one on the losing teams batting average is affected?
