A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified .
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
Buckling in horizontal vinyl siding is generally caused by
a) reflected sunlight
b) improper fastening
c) condensation in walls
d) improper house wrap
Which set of building terms do NOT belong together?
a) cripple trimmer, purlin
b) arch, header, lintel
c) rafters, ceiling joists, trusses
d) sheathing, flooring, decking
A ground fault occurs when
a) too many devices are used on a circuit
b) a hot conductor touches another hot conductor
c) a hot conductor touches a grounded surface or grounding conductor
d) a grounded conductor comes in contact with a grounding conductor
While inspecting a heat pump in the cooling mode, you measure a 28 degree F temperature differential between the interior supply and return air. You should suspect
a) an exterior fan running too slowly
b) an overheating compressor
c) a dirty filter
d) a thermostat set too low
Capillary tubes are part of the
a) evaporator coil
b) heat exchanger
c) condenser coil
d) compressor discharge
Wtg!
I am curious about the capillary question… I assume you mean the suction line, which travels all throughout the system. So why say it is only part of the evaporator?
The capillary tube is actually on the high pressure side of the system. So to say the capillary tube is only part of the evaporator would be like saying the compressor is only part of the condenser.Given the limited choices, I would have answered A & C. But I learned long ago that this contest is more of an exercise of “guess what I’m thinking”.
A capillary tube is nothing but a long, fixed-length tube with a very small diameter that is installed between the condenser and the evaporator. The capillary tube actually meters the refrigerant from the condenser to the evaporator.
Peter can also explain his answer. Just trying to help out.
Congratulations John Milholland, good job.
Your name hase been posted here; iNACHI Awards Chapter - InterNACHI® along with the other winners.
Always nice to see new players.
