Questions Of The Week February 22
HOWDY & Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions.
Correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping
Choose your prize from the following list!:
>$50.00 gift certificate from Inspector Outlet
>Case of books “Now That You’ve had A Home Inspection”
A dozen Honey Crisp Apples from Mr. Ryan Uecker’s almost famous recipe.
Good luck!
  1. Peter Giannino wants to know
    A landing may not be needed for exterior steps
    a) when it is a secondary entrance and there are three or fewer risers
    b) where there are three or fewer risers, regardless of which entrance it is
    c) if the steps have a handrail that is not at least 30 inches tall
    d) where there are fewer than six steps
    e) when the door opens inward
2) What is not considered to be an effective ground-fault current path?
3) Kevin M. Leonard CMI wants to know
What is the most common problem found during a deck inspection?
A. Deck boards that are not pressure treated.
B. Posts that failing due to being undersized.
C. Ledger boards that are not properly attached to the structure.
D. Improper post to beam connections.
4) Inspect this please
5) Microscopic organisms, or microbes that can live on the outside of your AC coil and inside your drain pain are to blame for ________
Extra bragging credit
WHO sang this on WHAT song?
Uh uh uh, uh uh uh uh uh
Great QOTW, Marc. I think @ruecker uses those honey crisp apples to bait his deer stands! :+1: :wink:
Um, baiting would be illegal in my area JR. I don’t do illegal things.
(P.S. they like corn better) :deer:
We need more good honest folks like you around. :laughing:
@ruecker What’s the recipe? :grinning:
Great questions, Marc, :thinking:
good job Sir…
Some of these are challenging. :slightly_smiling_face:
Great questions Marc !!
Good questions Marc! :+1:
These are good ones, Marc!
Some tough questions but I’ll give it a shot.
  1. E, assuming that “may not” is the important phrase in the question.
  2. Earth, metal water pipes are also problematic due to the possibility of material changes (copper to plastic) and corrosion.
  3. C, is probably what I see the most from those choices.
  4. Unprofessional repairs around vent flashing and the flashing ‘edges’ are not visible to determine whether they over lap the tiles properly. Vent pipes do not extend high enough to completely clear the roofing materials.Wire mesh looks to be installed to prevent pest intrusion.
  5. Biofilm from the growth can cause clogging of the condensate drainage and resulting leaks.
Great QOTW Marc! :+1:
1 e
2 ground
3 c
4 Plumbing vent(s) too short
5 drain stoppage
EBC FUJIYA & MIYAGI UH!
Congrats to both @megbert2 & Dave Fetty. Two good answer sets.
The earth
Plumbing vent pipe(s) terminated less than 6 inches above the roof surface below.
Debris can block vent pipe extension openings with such short pipes. Blocked vent pipes can cause sewer gases to enter living spaces.
Recommended that a qualified contractor repair per standard building practices.
Dirty sock syndrome” in HVAC refers to a foul, musty odor, often described as smelling like dirty socks, that emanates from an air conditioner when first turned on, caused by a buildup of mold and bacteria on the evaporator coil, typically due to dust and moisture accumulation on the coil; this is usually a sign that the air filter needs to be replaced and the coils need cleaning.
Dirty Sock Syndrome: Causes & Solutions | Fire & Ice.
Greg Kihn Band-The Breakup Song
Woot, good questions this week.
Woo Hoo! Congratulations @megbert2 and @sfetty :boom: :heavy_dollar_sign: :boom: :dollar: :boom:
You know how to claim your prizes.
And, you are listed here:
Congratulations Guys, Nice!!
WTG Guys !!
WTG :+1:
