Questions Of The Week February 29!
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
https://certifiedmasterinspector.org/video-contest
**** Welcome to another round of Questions of The Week!
Please read the Introduction and requirements, changes may have been made.
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
The WINNER can now choose from any of the prizes listed above!
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Good luck! :cowboy_hat_face:
1)Two types of cracks brought on by premature drying
2) _______ are used as a point of separation (or isolation), between other static surfaces
3) Cooling systems ~ how many types?
4) Some swamp land bacteria, to off gas methane is inhibited by _______
5) Common trait of crocodiles, lobsters, Mandarin ducks
croc
mandarin duck
WHO sang this on WHAT song?
Just let yourself go down
Great questions, as usual, Marc! Thanks for doing them!
  1. crazing cracks and surface cracks
  2. grounds
  3. 4 types (central AC, evaporative coolers, mini splits and heat pumps)
  4. soil microbes and plants metabolizing under anaerobic conditions.
  5. they all lay eggs in water.
    Xtr) Let Yourself Go by Stealers Wheel
This week was tough. Good questions.
Good questions is right Jacob.
Thanks Marc.
  1. Crazing and crusting cracks
  2. Expansion joints
  3. 6 types: liquid-to-liquid, closed-loop dry system, closed-loop dry system with trim cooling, open-loop evaporative system, closed-loop evaporative system, chilled water system
  4. Acid rain
  5. Oviparous/they all develop in an egg
Extra: Wang Chung “Everybody Have Fun Tonight”
Dang! I think I misread #3! :stuck_out_tongue:
  1. Crusting and crazing
  2. Grounds
  3. 4: ductless minisplits, heat pumps, central, and evaporative
  4. Acid rain
  5. They are all oviparous (babies grow outside of mother)
    Wang Chung on Mosaic
Just hanging by a thread, as usual :blush:
There’s still time for someone to get them all right! :thinking:
Crazing and Crusting
Bonding, Grounding
4 Types
Acid Rain
They’re oviparous. They grow inside a shell, outside of the mother’s body
“Everybody have fun tonight” Wang Chung
Good questions Marc, thanks for your time!
There’s still time Dave! Get your answers in there! :smile:
More great questions from Marc! These are fun!! :smile:
1- Crazing,Crusting
2- Expansion joints
3- 2 types… Air cooling and Water cooling
4- Acid rain
5-Hyper-efficient breathing system
1)Crusting and crazing
2) Control joint
3) 2 - working and not working
4) iron
5) They can be found in southern Florida
Not much more guessing going on. This was a good week for some hard questions.
More participants this time, good to see!
CONGRATS Junior Fudge for the win!
Your #3 answer was not exactly what I was thinking, but the number types of six was correct, although Aaron had a great answer!
There are two common types of cracks brought on by premature drying.
Crazing cracks are very fine, surface cracks that resemble spider webs or shattered glass. When the top of a concrete slab loses moisture too quickly, crazing cracks will likely appear. While unsightly, crazing cracks are not a structural concern.
Crusting cracks typically happen during the concrete stamping process, which is a way of adding texture or pattern to concrete surfaces. On sunny or windy days where the top of the slab dries out quicker than the bottom, the top of the concrete surface can become crusty. When the stamp is embedded, it pulls the surface apart near the stamped joints and causes small cracks around the outside edges of the “stones”. Again, while they don’t look great, crusting cracks are not a structural issue to be considered about.
Expansion joints are used as a point of separation (or isolation), between other static surfaces. Typically made of a compressible material like asphalt, rubber, or lumber, expansion joints must act as shock absorbers to relieve the stress that expansion puts on concrete and prevent cracking
There are six different types of air conditioners that are each designed for a different space/reason. These six types of AC units are the basic central AC, ductless, window unit, portable unit, hybrid, and geothermal
NASA researchers recently discovered that one species of swampland bacteria’s ability to produce methane – a greenhouse gas that contributes to global warming – is actually inhibited by acid rain
https://www.nachi.org/acid-rain.htm
Oviparous Animals
https://animals.mom.me/list-of-oviparous-animals-7654874.html
Deep in the world tonight
Our hearts beat safe and sound
I’ll hold you so close
Wang Chung performing Everybody Have Fun Tonight. © 1986 Geffen Records
Over 12 million views
Congratulations Junior, well done.
Congratulations, Junior! Way to go!
