Here comes the results. It’s now OK to safely continue.
Snoop Dog has completed his investigation with help of his best friend Martha Stewart.
Turns out they were a FAKE AI messages from parts unknown.
Congrats to Ryan Uecker & Bryce Nesbitt.
1)The unit used for measuring electrical current is called
a) Electrode
b) Volt
c) Discharge
d) Ampere
The unit used for measuring electrical current is called ampere. Ampere is the SI unit of electric current, symbolized as A. It is named after the French physicist André-Marie Ampère. The ampere is defined as one coulomb of charge passing through a point in a circuit per second. It is commonly used to quantify the flow of electric charge in electrical circuits
2) Inspect this please
roof vent not 6 inch minimum
Plumbing vent pipe terminated less than 6 inches above the roof surface.
Debris can block vent pipe extension openings with such short pipes.
Blocked vent pipes can cause sewer gasses to enter living spaces.
3) The transference of heat definition:
Heating your cup of coffee in the microwave _______
You almost burnt your hand on the cup taking it out!_______
Radiation
Conduction
4) A leading cause of foundation failure
a) cement pour with no rebar
b) expansive soils
c) improper support features
d) improper drainage
e) OJ Simpson
d) Improper Drainage
5) After my inspection, there was NOTHING present to cause “the affliction”.
I was paid to perform a flea treatment, but only sprayed with WATER.
This pleased everyone & the “fleas” were then gone.
This type of scenario is known as _______ _______
Contagious Hysteria ~ note: sorta like “mob psychology”
As the name implies, imaginary pest infestations sometimes upset a group of people at the same time. This hysteria can be passed along or accepted by others. Contagious hysteria often occurs in an office work force. Factors usually connected with the hysteria include crowded conditions, overtime work, excessively detailed or boring tasks, changing climate, changing seasons, paper handling, perceived unfairness of working conditions caused by physical arrangements in the work space, etc. Classically, a few individuals, including a leader or spokesperson, begin feeling bites and discover rashes and other skin eruptions. These individuals identify certain portions of rooms where the pests are common and demand control. Supervisors usually do not believe there is a pest problem because they are usually unaffected by the contributing conditions, but they may be recruited as pressure for results mounts. When careful inspection for mites, psocids and other pests fails to reveal culprits, premises should be checked for allergens and irritants such as insect parts, fiberglass fragments, static electricity, volatile materials, etc. Pesticide application in these cases should be avoided.
Music Question
WHO sang THIS on WHAT song?
wishing my whole life away
Uriah Heep Easy Living 1972
