HOWDY & Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions.
Correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submit your Mailing address for shipping
Choose your prize from the following list!:
>$50.00 gift certificate from Inspector Outlet >Case of books “Now That You’ve had A Home Inspection” 14 cases of the FAMOUS Grippo’s Hot & Spicy Popcorn personally delivered by Mr. Larry Kage (not availible in Ohio)
1)The unit used for measuring electrical current is called
a) Electrode
b) Volt
c) Discharge
d) Ampere
2) Inspect this please
3) The transference of heat definition:
Heating your cup of coffee in the microwave _______
You almost burnt your hand on the cup taking it out!_______
4) A leading cause of foundation failure
a) cement pour with no rebar
b) expansive soils
c) improper support features
d) improper drainage
e) OJ Simpson
5) I was called by a bank to perform an emergency flea treatment. Some of the office personnel were complaining & itching!
The employees including a leader began feeling bites and discovered rashes and other skin eruptions. These individuals identified certain portions of rooms where the pests are common and demanded control.
After my inspection, there was NOTHING present to cause “the affliction”.
I was paid to perform a flea treatment, but only sprayed with WATER.
This pleased everyone & the “fleas” were then gone.
This type of scenario is known as _______ _______
WHO sang THIS on WHAT song? wishing my whole life away
2-Roof vent pipe shows signs of a patch repair. Recommend further evaluation by a qualified roofer.
Issues: The vent top is low especially for an area with snow. The flashing which sheds water is of a long lasting type using soft metallic lead: however it appears uneven and may have been torn or damaged. The patch is suspect, as no patch should be required when using this type of flashing.
3 - no (microwave heating of water) yes(cup to hand) Edit based on instruction to fill in the blank:
Heating your cup of coffee in the microwave ___ (radiant)____
You almost burnt your hand on the cup taking it out!__ (conductive)_____
4 - All but E are leading causes of foundation failure. Edit based on instruction to select a single best answer:
The best single answer is D.
5 - “Psychosomaticresponse”
(Or perhaps the inspector “missingsomething”).
Easy livin’ by Uriah Heep on Demons and Wizards.
covered by WASP and a wide variety of others.
I have received 4 text messages & 1 voice mail in the last hour from someone in a higher order than myself. I have agreed to be bound by the messages (could be veiled threats).
So… … … Mr. Bryce Nesbitt is allowed to edit his responses without being in jeopardy of the evil disqualification.
