HOWDY & Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time. Eligible members may make one post per question thread to answer the questions.
Correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submit your Mailing address for shipping
GOOD LUCK!
Choose your prize from the following list:
>$50.00 gift certificate from Inspector Outlet
Case of books “Now That You’ve had A Home Inspection”
Fourteen DELICIOUS sandwiches made out of: Ground pork shoulder (and sometimes other pork parts) that’s been restructured and formed into a rib shape(limited time only) AKA McRib
Please be sure they are offered in your area by checking first
WHY is the cold on the right & hot on the left?
2) Are there major differences between sewer and septic systems in your home?
4) All plumbing fixtures listed below are included under the definition of a plumbing unit except:
Water meter
Lavatory
Water closet
Urinal
(OJ Simpson ~ just a joke)
5) A stop valve in a service pipe close to its connection with a water main is a:
Gate valve
Corporation cock
Check valve
Globe valve
WHO sang THIS on WHAT song? I pick myself up off the ground
1 Most people are right handed and cold was typically on the right, with the advent of heated water , the logical place “left” to put it was on the left.
2 Septic has a tank and leach field
3 Improperly installed plumbing vent boot, likely roof leak.
4 Water meter
5 Check valve
BQ Nick Lowe Cruel To Be Kind
WHY is the cold on the right & hot on the left? When indoor plumbing was first introduced, there was one option that came out of the hand pump: cold water. There was no hot water. Since the majority of people are right-handed, the pump was placed on the right side of the sink. The logic for keeping the cold/right, hot/left placement – is to avoid surprises. We tend to reach for the right side first and by having the cold there, it helps to avoid accidental scalding
a) They are very similar
b) One uses pressure and the other uses gravity
c) The only difference is in the type of pipes used a) They are very similar, both systems are basically the same
Plumbing stack flashing damaged/open. Recommend sewer scope due to pipe is cast iron.
Water meter
Lavatory
Water closet
Urinal
(OJ Simpson ~ just a joke) Water meter
Gate valve
Corporation cock
Check valve
Globe valve A corporation cock is a type of valve that is commonly used in service pipes near their connection with a water main. It is designed to regulate or stop the flow of water in the pipe. This type of valve is typically used in municipal water systems and is known for its durability and reliability
NICK LOWE - CRUEL TO BE KIND
PS… The woman in the video is really his wife.
Who She Is: Carlene Carter, a musician from the famous Carter Family.
Her Role: She plays herself in the video, which documents Lowe’s wedding to her in 1979.
Video Content: The video blends real wedding footage with humorous reenactments, showcasing their actual wedding at the Tropicana Motel
