Questions Of The Week May 24
HOWDY & Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time. Eligible members may make one post per question thread to answer the questions. Correct answers (as judged by the Awards Committee or Poster of the Questions) wins. Request your choice by emailing [email protected] and submit your Mailing address for shipping GOOD LUCK!
**Choose your prize from the following list:
$50.00 gift certificate from Inspector Outlet
Case of books “Now That You’ve had A Home Inspection”
Last time we could choose from the hot sauce collection of JR Scott Fudge !
This time, a member that wishes to remain anonymous, has donated one of the hot sauces from his prized collection!
  1. Approx. how many insects for each person in the world?
2) In a parallel circuit, if one component fails, what happens to the other components?
a) They all stop working
b) They continue to work
c) They become brighter
d They become dimmer
3) Describe at least five functional requirements of a roof
4) Flexible water connections are required to be ____
a) Readily accessible
b) Accessible
c) Limited to first-floor installations
d) Supported
e) Within sight of fixture
f) soft but cute
5) What are the most common causes of sink blockages
a) garbage
b) toilet paper and air freshener
c) solidified detergents and toothpaste
d) grease and hair
e) Martin Willes
WHO sang this on WHAT song?
I’ll say what you wanna hear
Nice questions sir…all of the above…I win again…
Nice QOTW, Marc. :wink:
Great questions, Marc, :thinking:
  1. 1.4 billion insects per person
  2. B they continue to work
  3. Weather protection, thermal insulation, structure and stability, moisture control, noise reduction
  4. A readily accessible
  5. D grease and hair
  6. I’m Telling You Now, by Freddie and the Dreamers
I’ll give it a shot.
  1. The scientific consensus estimate is about 200 million insects per human.
  2. b. In a parallel circuit, each component has its own independent path.
  3. Weather protection, Structural support, Drainage, Thermal performance, and Durability & longevity.
  4. a. Readily accessible.
  5. d. Since this is a kitchen, I would say grease. Hair would be more apt in the shower drains.
  6. “Say What You Want” by Texas, sung by Sharleen Spiteri.
Great questions Marc !!
As always, great QOTW, Marc… :+1:
Good QOTW Marc! :+1: :+1:
:united_states:
  1. 1.4 Billion
  2. b
  3. Keep the rain out, keep critters out, protection from sun, allow water to drain from structure, protection from wind, protection from fire
  4. a
  5. d
    Martin may be the most common cause of unblocking clogs
MQ
Devon Baldwin – Keep On Loving Me
This week’s winner is David Mattoon.
Dave Fetty got them all correct also, so I used the music question for the tie-breaker.
:smiley:
    There are approximately 1.4 billion insects for every person on Earth. The total weight of all the insects is about 70 times more than all the people.
In a parallel circuit, if one component (such as a light bulb or resistor) stops working, all other components in the remaining branches continue to function normally. Because each component has its own independent path to the voltage source, the failure of one branch does not break the circuit for the others
Strength and stability.
  • Resistance to weather.*
  • Durability and freedom from maintenance.*
  • Fire safety.*
  • Resistance to the passage of heat.*
  • Resistance to the passage of sound.*
  • Resistance to air leakage.*
  • Security.*
  1. Flexible water connections are required to be ____
    b) Accessible
    d) Supported
    f) soft but cute
    All flexible water connections are required to be accessible (IPC 605.6; UPC 604.5). This means that they can be concealed in a cabinet or behind an access panel, but they must be accessible
a) garbage
d) grease and hair
e) Martin Willes
d) grease and hair
Grease & hair are the most common causes of sink blockages
Freddie & The Dreamers - I’m Telling You Now
Congrats David!
Congrats on the win @dmattoon :+1:
Congrats, David, Nice!
Yippeee! Thanks, Marc!
WTG, David. :wink:
WTG David !!
Good job, David.
