Questions Of The Week October 10
Welcome To Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
  1. Kenton Shepard asks:
    What is the problem with two grounding electrodes installed on opposite sides of a house that has a single electrical system?
2) The estimated life expectancy of equipment based on real world conditions is also known as design life
true or false
3) Building finishes are not considered as components of a building
true or false
4) Assuming stable fuel, heat, and oxygen levels, a typical house fire will double in size every _______ minutes
a) 10 minutes
b) 5 minutes
c) two minutes
d) one minute
5) Existing knob-and-tube wiring should be replaced
a) because its design is known to be defective
b) because it is prone to be a hazard
c) if a grounded circuit is desired
d) because it is no longer allowed by any electrical codes
e) OJ says no
WHO sang this oin WHAT song?
Looked a lot like yours
Great questions Marc !!
Great questions, Marc. :+1: :slight_smile:
all Of the above !!!
  1. Code allows the resistance to earth of a residential ground rod to be as high as 25 S. It is far too high to trip the circuit breaker under fault conditions in the dangerous hookup of two ground rods. The soil resistance between separate ground rods can also allow thousands of volts to develop between them if lightning strike current should actually flow in one of them.
  2. False
  3. False
  4. D
  5. C
“Pickup,” by MacKenzie Porter
David got 'em & scared everyone away!
Congrats to David Rey - nice job!
current traveling through soil between them may energize underground metal components
true or false
false - answer is service life
true or false
False
Building finishes are also part of the building. Finishing works include plastering, whitewashing, painting, flooring, roofing and so on. These all add to the completion of a building
a) 10 minutes
b) 5 minutes
c) two minutes
d) one minute
d
e) OJ says no
c
WHO sang this on WHAT song?
MacKenzie Porter - Pickup
WTG David !!
Congrats, David! :+1: :slight_smile:
@drey is a smartie pants. Wtg David!
lol, thanks everyone.
