Questions of the week;**
Introduction and requirements:
A member of the Award Committee will post a question, at a random day/time.
A competing member may make one post per question thread to answer the question and the member’s winning entry must have all parts of the question answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Winnings will be limited to no more than 6 times in a given year, the objective is to allow as many Members a chance to win as possible.
Any disregard to the above and divulging the correct answers will forfeit the weekly winnings.
So please refrain from participating if you have already won in the maximum for the Year.
First correct answer (as judged by the Awards Committee or Poster of the Question) wins.
The lucky winner will get a case of “Now that you’ve had a Home Inspection Books” shipped to them at their address on file. Make sure your Address on File with Inachi is correct.
Courtesy of Nick Gromicko.
Winners of the Question of The Week shall request their prize by emailing fastreply@nachi.org and submitting their Mailing address for shipping.
Allow 2 weeks for delivery.
Questions**
**1. If you want to check something for square, such as a mall or door frame for square you can use **
a. Equal laterals Trick
b. Corner squat trick
c. Pythagorean triples trick
d. All of the above**
- Mold growth is a concern primarily on**
a. Cellulose insulation
b. Fiberglass insulation
c. Open cell foam insulation
d. Extruded Polystyrene Rigid Foam Insulation
3. The absence of detection of flue gases or carbon monoxide using a quality gas detection device is a guarantee that the heat exchanger is not damaged and leaking. T/ F
4. When you observe a chimney with a split the best course of action is
a. Tear down and build a new chimney
b. Fill the split with new mortar
c. Install a liner and then mortar the chimney.
d. Mortar, liner and install stainless steel band clamps
