Rafter Purlin Bracing
Attached are two graphics showing rafter bracing down to a support wall and one with an added beam when there is no support wall. Note: The added beam should be supported at both ends on a support wall. If the brace on top of the beam is at an angle, then the beam will need some lateral bracing to prevent roll over.
Thanks, Randy. :slightly_smiling_face:
Another great illustration.
