How would you report and inspect the following conditions.
Exterior air conditioner exterior disconnect hinge/latch rusted/painted.
Access panel for tub plumbing has 4 screws painted and there is moderate storage in front.
No access panel for a 2nd floor tub more than 20 years old.
Car located under garage pull down ladder.
Main panel has a stackable washer/dryer unit within 2 inches of panel. 2 screws are accessible.
Crawl space off basement. Large enough access to enter. Storage cabinets in front of access.
1st floor whirlpool tub, finished fixed basement ceiling. No access at tub.
GFCI has a refrigerator and microwave plugged in. Occupied house.
Masonry block foundation, recently painted, Insulation on 25% of walls, 25% storage, no recent rain. 70% humidity in basement, glade air fresheners, fan running, carpet on 100% of floor. No signs of moisture.
Gas company turned gas off to fix riser an hour after you arrive to inspection. Home has a gas fireplace, water heater and furnace. Gas was on long enough to test fireplace. 120 degrees hot water observed. Gas off when testing water heater and furnace.
Thanks for the time.
