Keep getting recalls from China Manufactured Products every night of the week almost.
Stop buying.
http://www.cpsc.gov/cpscpub/prerel/prhtml12/12198.html
WOW! Thanks for posting that Marcel.
And another tonight, guess where it is made.
http://www.cpsc.gov/cpscpub/prerel/prhtml12/12200.html:)
This recall made in USA. Might be seen during an Inspection.
http://www.cpsc.gov/cpscpub/prerel/prhtml12/12201.html
Hazard: The system can burst at or near the vessel weld seam releasing stored pressure. This pressure can lift the tank lid and shatter the tank, posing impact or laceration hazards to consumers and property damage.
Thanks for posting I think.
It was sold for 11 years and a total of nearly 2.5 million.
I seldom look in the toilet tank unless it fails to flush.
I have no plans to change that procedure.
If fact it may be time to include a disclaimer in my report and refer my client to the CSPC site.
There simply are far too many things that can go bump.
Inspectors are not magicians and fortune tellers.
Observe
report
get paid
go home
sleep well
It sounds like Nathan has a service that many benefit from. Do all members that use his service, described here, alert the client that they make comissions from the client’s use of his service? Just curious how users are advertising it. Thanks.
Don’t let this one become a fireworks for your Kids.
Overseas Manufacturers at their best;
Check out your gas Dryers please;
http://www.cpsc.gov/cpscpub/prerel/prhtml12/12251.html
LG Electronics and Sears Recall Gas Dryers For Repair Due to Fire Hazard
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firms named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately until a repair is completed on affected dryers. It is illegal to resell or attempt to resell a recalled consumer product.
**Name of Product: **LG Electronics and Kenmore Elite® Gas Dryers
**Units: **About 21,000
**Manufacturer: **LG Electronics, Inc., of South Korea
**Hazard: **The gas valve in the recalled dryers can fail to shut off properly, continuing to heat the dryer and its contents after the drying cycle is complete. High temperatures inside and on the exterior surface of the dryers can scorch the drum, as well as burn or damage the dryer contents, posing a risk of burn, fire and smoke inhalation.
**Incidents/Injuries: **LG Electronics and Sears have received 141 consumer complaints about dryers continuing to heat after the drying cycle is complete. There were three reports of minor burns to hands or arms. Burnt or scorched clothing was reported in more than 50 incidents.
**Description: **LG Electronics and Sears’ Kenmore Elite brand gas dryers come in the following colors: LG models in white; Kenmore Elite® in red, white and ginger (gold). Model and serial numbers can be found on a label fixed to the front of the dryer above the opened door, which can be viewed only when the dryer door is open. To confirm if your dryer is part of this recall, identify both model and serial numbers, since not all dryers with the listed models are recalled.
This one here could be in your house.
Wing Enterprises Recalls Switch-it Stepladder/Stepstools Due to Fall Hazard; Sold exclusively at Home Depot
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed. It is illegal to resell or attempt to resell a recalled consumer product.
**Name of Product: **Stepladder and Stepstool Combination
**Units: **About 20,000
**Importer: **Wing Enterprises Inc., of Springville, Utah
**Manufacturer: **Suzhou Zhongchuang Aluminum Products Co. Ltd.
**Hazard: **When extended, the inner side rails can separate from the outer side rails causing the user to fall.
**Incidents/Injuries: **Wing Enterprises has received nine reports of the ladder becoming unstable causing the user to fall and sustain injuries ranging from scrapes and contusions to a fractured collar bone.
**Description: **The recalled products are Switch-it Type 1A Stepladder/Stepstools rated at 300 pounds. The Switch-it is an aluminum ladder that can be extended from a 2-foot stepstool to a 6-foot stepladder. It has flared C-channel outer rails that fit over inner rails. The outer rails have orange rocker-type locks on each side to hold the outer rails to the inner rails. The words “Switch-it by Little Giant” appear on the front of the top platform. Recalled Switch-it stepladder/stepstools have the following date stamps: 10622S, 10623S, 10624S, 10721S and 10722S. The date stamp is located immediately below the orange locks on the outer rails. Part Number “15124” is on the black and orange notice label attached to the back of the outer rails.
**Sold Exclusively at: **The Home Depot and online at Homedepot.com from August 2012 to October 2012 for about $88.
**Manufactured in: **China
**Remedy: **Customers should immediately stop using the recalled stepladder/stepstools and contact Wing Enterprises for a free replacement of the front outer section.
**Consumer Contact: **Wing Enterprises Inc.; toll-free at (855) 595-3378, from 8 a.m. to 5 p.m. MT Monday through Friday, or online at www.littlegiantladders.com/switch-it-recall, for more information.
http://www.cpsc.gov/cpscpub/prerel/prhtml13/13063a.jpg
Switch-it stepstool /stepladder in the 2-foot stepstool configuration
http://www.cpsc.gov/cpscpub/prerel/prhtml13/13063b.jpg
Switch-it stepstool /stepladder in the 6-foot stepladder configuration
http://www.cpsc.gov/cpscpub/prerel/prhtml13/13063c.jpg
Switch-it stepstool /stepladder in the staircase-ready stepladder configuration
[size=3]The U.S. Consumer Product Safety Commission (CPSC) is still interested in receiving incident or injury reports that are either directly related to this product recall or involve a different hazard with the same product. Please tell us about your experience with the product on SaferProducts.gov
CPSC is charged with protecting the public from unreasonable risks of injury or death associated with the use of the thousands of consumer products under the agency’s jurisdiction. Deaths, injuries, and property damage from consumer product incidents cost the nation more than $900 billion annually. CPSC is committed to protecting consumers and families from products that pose a fire, electrical, chemical, or mechanical hazard. CPSC’s work to ensure the safety of consumer products - such as toys, cribs, power tools, cigarette lighters, and household chemicals - contributed to a decline in the rate of deaths and injuries associated with consumer products over the past 30 years.
Under federal law, it is illegal to attempt to sell or resell this or any other recalled product.
To report a dangerous product or a product-related injury, go online to: SaferProducts.gov, call CPSC’s Hotline at (800) 638-2772 or teletypewriter at (301) 595-7054 for the hearing and speech impaired. Consumers can obtain this news release and product safety information at www.cpsc.gov. To join a free e-mail subscription list, please go to www.cpsc.gov/cpsclist.aspx.
http://www.cpsc.gov/images/ConnectA.jpghttp://www.cpsc.gov/images/onsafetyboilera.jpghttp://www.cpsc.gov/images/YoutubeA.jpghttp://www.cpsc.gov/images/TwitterA.jpghttp://www.cpsc.gov/images/FlickrA.jpg
[/size]
Below is the Canadian website for recalls:
If I were still an inspector, I’d be doing Nathan’s RecallChek.
This link takes you directly to the consumer recall site.
http://cpsr-rspc.hc-sc.gc.ca/PR-RP/home-accueil-eng.jsp
