I had a client this morning who requested an IR scan of his living area due to major ice dams. I did my IR scan and inspected the attic and advised him on how to properly correct the ice dam issue.
My question is…What the hell causes the exterior cedar siding to stain so bad during an ice dam situation?
Is this stain from the actual cedar siding seeping (tannin bleed) and running down the side of the house?
David: Did both buildings have a new roof installed?
After a tear off, there is a lot of debris in the soffit area left behing sometimes. Asphalt, sawdust, dislodged dirt and “crap” from between the roof materials.
I can’t think of a new england used material that would come apart in an ice dam situation that would hold so much staining material at one time.
David, I have had experience with this brown staining of the cedar before.
The jobs I worked on showed similar staining on the building wrap behind the siding, but the leaching was minimal on the surface.
Moisture behind the cedar siding or cedar trim at soffits, if not back primed with an oil based primer that locks in the tannin in the cedar, it will leach out behind the siding or where ever it can come out on the surface of the trim.
Cedar should be sealed with oil based primers front and back before application of any water based finsish paints.
I have pictures somewhere on a disk in files somewhere.
**[FONT=Bliss-Bold][size=3][FONT=Bliss-Bold][size=3][size=2]Multi-Purpose Oil-Based Primer
**[/size][/size][/FONT][/size][/FONT][FONT=Bliss-Regular][FONT=Bliss-Regular]Even though it’s oil-based, this versatile sealer is low odor – making it a great choice for using in occupied
areas. It’s an exceptional whole-house primer that really does live up to its functional name.
[/FONT][/FONT][FONT=Bliss-Regular][FONT=Bliss-Regular]• Can be used on many interior surfaces – including wood, hardboard, cured plaster, paneling and
[/FONT][/FONT][FONT=Bliss-Regular][FONT=Bliss-Regular]ceiling tiles
[/FONT][/FONT][FONT=Bliss-Regular][FONT=Bliss-Regular]• Seals out odors and great at blocking stains – especially wood tannin stains and water-based stains
• Dries quickly and assures a uniform finish
My family and I are doing very well. The kids are growing faster than weeds and my inspection business does just fine. I hope you and yours are doing well also.
