Red sealant
Could someone explain to me about the red sealent.
What is it?
I have seen the sealant before. I thought this application was sloppy.
Is it really needed. It looks like ****.
Thanks
Dave
It is fire caulking.
http://www.safetythink.com/Workplace+Safety/Flame+Stop+V+Caulking?gclid=CL2imJ-2s4gCFQYtUAod0ROy1g
So is it safe to assume that this was a homeowner attempt?
The same person that used a can of foam spray to try to stop a drain leak.
Dave
It looks like high temp RTV.
I think they need to use it up at the roof, from the looks of the water staining on the joist.
Assume nothing. The fire caulk costs about $15 a tube, and it’s right next to caulk for $1 a tube. So what would a ‘home owner’ choose?
tom
I’ve seen similar sealant used in an attempt to seal cracks in a heat exchanger. It was described to me as a high-temperature sealant.
Red RTV gets my vote, if it feels rubbery 98% chance it is.
Red RTV
yes, around here it is called red rtv but it is not at home depot ( at least not the good stuff) it is only available at the plumbing supply to plumbers, (not sure why) I had some applied to my heating system.
