Repair, Replace, or Monitor
(Brian E. Kelly, AZ Cert. # 60234) #1
Check the photo and vote :D
(John Kogel) #2
Old guys, repair it, young guys, replace it, realtors, twist it open, twist it shut till it breaks. :p
John Kogel
www.allsafehome.ca
(Bob Elliott, 450.0002662) #3
Why?
Because the guy spilled stucco? :)
(Brian E. Kelly, AZ Cert. # 60234) #4
[quote="relliott, post:3, topic:36856"]
Why?
[/quote]
:mrgreen::mrgreen::mrgreen::mrgreen::mrgreen:
(Joe Funderburk, CMI) #5
I don't usually use the "repair, replace, or monitor" language. Rather, I usually say it "needs service" or "needs a further evaluation by a specialist". I usually leave the decision about whether a repair or replacement is warranted to a licensed contractor.
In this case, I'd say something like "the valve has corrosion may have sealed itself, but should be evaluated by a licensed plumbing contractor and serviced as deemed necessary."
(Wayne B. Wilson, TN 439) #6
LOL that was a trick! quick look i said replace second look clean Mortar off check for leak. Good one
(Brian E. Kelly, AZ Cert. # 60234) #7
[quote="wwilson3, post:6, topic:36856"]
[/quote]
It is not Mortar Wayne. Here is hint, I would not even touch that valve unless I had another one with me and a torch nearby. :D:D
(Wayne B. Wilson, TN 439) #8
Your kidding well replace for sure from the picture it looked like mortar had been dropped on it . If it has been leaking the long it is time to go
(James H. Bushart) #9
I leave it to the contractor and simply recommend that a qualified plumber be hired to repair or replace, as necessary.
(Bob Elliott, 450.0002662) #10
I used to let those things self heal all the time.
Looks good to me.:)
Cough cough...of course I was just kidding.
(Wayne B. Wilson, TN 439) #11
Hope the ground wire is on both sides
(Christopher Currins, CMI) #12
http://www.nachi.org/forum/attachments/f22/27210d1236138520t-repair-replace-monitor-6130-w-quartz-3-3-09-023.jpg Did it taste like mold?
(Bob Elliott, 450.0002662) #13
[quote="ccurrins, post:12, topic:36856"]
[/quote]
You would know what Mold tastes like ,wouldn't you Chris
(Jae Williams) #14
[quote="jfunderburk, post:5, topic:36856"]
[/quote]
Exactly what I would have said...well, pretty close, anyway...or...sort of??
Hmmm, I would have said something like that.;);)
(Tim Spargo, CMI) #15
"Repair" with close to same verbage as above... even though It's going to evolve into a ball valve if a plumber looks at it..
Oh... don't forget to scrape the minerals off as we need them in our daily diet
(Brian E. Kelly, AZ Cert. # 60234) #16
I recommended repair by a plumber on this one, and verbally mentioned a ball valve.
I personally would have no trouble telling a client to replace that valve though either. :D
(David P. Valley) #17
[quote="bkelly2, post:16, topic:36856"]
[/quote]
I was going to state the same.
It's not that expensive to replace a shut-off.
