Return Air Venting
Originally Posted By: janderson
I recently inspected a townhouse and ran across an interesting situation. The forced air furnace is located upstairs and is a downflow type. What I discovered is that there are no return air vents located downstairs at all. icon_eek.gif
The furnace is located in a closet/laundry room upstairs. The only return air intake is located directly on the other side of the wall from the furnace. The return air enters directly into the plenum through a vent installed on the other side of the wall. A filter was installed in this area and it was completely filthy (causing all sorts of other problems)
I am no mechanical expert, please advise if there is a requirement for return air ducts installed throughout the dwelling.
Within the seeds of ignorance lie the fruits of denial
Jeremiah
Well, the silence is somewhat reassuring. icon_wink.gif I advised the client, that this was not a typical installation for a forced air system and that they could expect noticeable temperature differences between downstairs and up.
Jeremiah
Originally Posted By: rking
Jeremiah,
That is a typical installation in mobile homes and some older homes with limited space and small crawlspaces.
Provided that the furnace was properly vented and had a sufficient supply of combustion air, it should not be much of a problem. Of course the fan would most likely have to work harder therefore shortening it's lifespan.
Although I can honestly say I have never seen a furnace installed in such a manner in a two storey dwelling.
Muskoka Home Inspections
"Wisdom is the Anticipation of the Consequences"
Steering Committee Member At Large
Everything else relating to the installation appeared good, combustion air, venting, ect…However, this was a first for me and given the fact that 11 other units had furnaces installed this way I was a little worried about making waves with this one.
Jeremiah
