Reverse Osmosis??
What is a reverse osmosis system? I had never heard of it before. I take it that it is some sort of filtration system??? icon_question.gif
Originally Posted By: jbehling
yes, water purifier system, do a search on the net, lots of info!
http://www.ohiopurewaterco.com/reverse-osmosis.html
Originally Posted By: jpope
hooked up improperly with a direct tap at the drain/waste line
![](upload://9XnZy6BIX0P2J4YnrS7viNfrH99.jpeg)
The 2003 IRC and the UPC require these to be installed with an air gap. It's rare that I find one hooked up properly, but I'll snap a picture the next time I do.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
I generally exclude water filtration and water softening systems. Do you guys inspect them?
BTW...thanks for the links and information! ![icon_smile.gif](upload://b6iczyK1ETUUqRUc4PAkX83GF2O.gif)
I don’t inspect the filtration system, but the improper tap needs to be reported.
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: jhagarty
http://www.ext.nodak.edu/extpubs/h2oqual/watsys/ae1047w.htm#what
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: jmaxfield
Newer R.O. systems often have the air gap built into the single touch faucet, you can tell if the drain line runs down from the bottom of the faucet.
Originally Posted By: rwashington
Welcome to NACHI! Must be a tough life inspecting in paradise.
Richard W Washington
www.rwhomeinspections.com
