*A technical change has been made to the footer on Page 1 of the OIR-B1-1802 to reflect the language used on Pages 2-4. The change is highlighted below:
*This verification form is valid for up to five (5) years provided no material changes have been made to the structure or inaccuracies found on the form.
Attached is a copy of the revised form filed with the Secretary of State which should be used for inspections from this date forward.
Any questions should be emailed to Cindy Walden at [email protected]
Thank you,
Cindy Walden
Government Analyst I
Office of Insurance Regulation
Property & Casualty Product Review
(850) 413-2616 (Phone)
(850) 922-3865 (Fax) [email protected]*
…I’m having trouble attaching the revised form (the attachment with the email). Seems to be too large of a file size. When I figure it out, I post it…unless someone else does it first.
What difference does it make. All of the reinspections and 1/2 of the previous inspections are not even on the original doc and they are accepted daily.
Manuel, instruction booklet translating the definition of each question
2)An appeals board to define the intent of each question
3)The old forms definition verus the new form (e.g. 3 nails, 4 nails)
4)How can the form reference the FBC and then ignore it on other questions
5)Source for reference
Define inaccuracies:
in·ac·cu·ra·cy
/ɪnˈækyərəsi/ Show Spelled[in-ak-yer-uh-see] Show IPA
noun, plural in·ac·cu·ra·cies for 1. 1. something inaccurate; error.
So now a misspelling, wrong date, typo, etc… will cause the form to be null and void. What if the form is changed within the 5 years and the newer form makes the older form question answers inaccurate.
Mikey,
I don’t understand why you want to whine and moan all the time, if you don’t like it go back to stucco work.
The verbage you are complaining about has always been on the other 3 pages, to include page 4, the signature page.
It is crazy to get upset about this change. If the inspection is wrong it should be rejected. Those of us who do accurate inspections will benefit from this.
As a professional inspector accuracy is our duty. John says it best, “I fill out a form.” No emotion. For every incident where an insurance company makes a mistake there are two where inspectors purposely lied on a wind mitigation and three where the inspector did not know how to do the inspection.
This forum needs an area for those who need to cry can do so in private.
