Hi everyone,
I wanna install roof gutters. I brought the necessary things that my friend recommended. He told me that i should call the person for installing it. But i want to do it by myself.
Have anyone installed the gutters by themselves. Then please do guide me with the same.
This is really a two person job. Downspouts recommended every 25 feet, max drop one eighth to a foot. If you are trying to use connectors, be sure to lay the butyl caulk to them. At the ground, extend the downspouts four feet away from the building. Fasten the gutter every two or three feet. Is that enough?
Yes I completely agree with you that in order to install it you will need at least two persons. Though the procedure of installing it is easy but one person cannot install it alone.
Yes I completely agree with you that in order to install. it is easy .
