It is a 1957 modern home with cathedral T&G wood ceilings. At the last re-roof they added rigid insulation on top of the structure. I don't know if it is above or below the paper but it would seem to me that this would move the condensation point to where the sheathing is, causing moisture damage. Any other thoughts?
Originally Posted By: dvalley This post was automatically imported from our archived forum.
Improper installation of roofing shingles and rigid board (if that’s what that is). Those shingles that are lapped over at the edges should last about three years. Guaranteed to leak at those edges.
Recommend a professional roofer evaluate and estimate repairs of roofing shingles.
Originally Posted By: lewens This post was automatically imported from our archived forum.
If that was done by a “roofer” I think they should find a better one. In the very least the rigid foam should have been flashed and the shingles brought to it and not lapped over. I personally would be ashamed to call that work mine. I can think of quite a few potential problems occurring from the insulation not the least of which is ventilation under the rigid foam. If the foam it’s self is not the proper type it will start to deteriorate very quickly, the shingles will start to dip and pocket, water will pool in small places on the roof etc.etc.etc. This is a boondoggle in the making.
