roof to sidewall flashing
Originally Posted By: jane molina
Hi Guys/gals ,Is this flashing correct ? As you can see the slope side is
tucked underneath the shingles but the flat roof side is on top of
the shingles . It continued on from the slope . Shoulld it not all be
underneath?
[ Image: http://www.nachi.org/bbsystem/usrimages/more/flash.JPG ]
Originally Posted By: Timothy Pope
From this diagram the installation appears correct.
http://www.nachi.org/tips/0078.gif
Originally Posted By: phinsperger
If I zoom in real close I think I see the vertical lines of step flashing on the slope which is correct.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: pdacey
If you zoom in, the flashing to the left is under the shingles and the flashing to the right is on top of the shingles. This would be correct. The flashing also appears to be counter flashed at the intersection with the siding. Unable to tell if the counter flashing is let in to the siding or just attached and sealed to the surface.
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
Thanks guys
As usual you have been a great help. I was wondering , why doesn’t all
the flashing just be underneath or on top , why one on top and one underneath?
Originally Posted By: rcallis
The direction of the slope dictates the flashing. Just look at the shingles.
Reggie
