I have not seen this roofing type before. It is a flat roof that at first glance I thought was an EPDM. Looking closer, there were strands of fiberglass visible. Could this be a glass reinforced plastic (GRP) roof?
I am certainly not an expert and never seen it before either… It looks like it could be fiberglass-reinforced asphalt sheet. My suspicion is that it originally had granules that are now completely worn off.
I have not seen this material before - need @rclaus to chime in on this one.
That’s what I would lean towards after some web searching…(glass reinforced plastic ~GRP~ roofing)
How old was the house?
More info here.
Maintenance And Longevity
“GRP roofs typically require minimal maintenance. Regular inspections focus on surface damage, UV wear, and flashing integrity. Remove debris and clean with mild detergent to preserve UV resistance and aesthetics. Address any cracks or hail marks promptly to prevent water ingress. With proper care, well-installed GRP roofs can last 20–50 years depending on climate, resin type, and maintenance frequency.”
If the surface is worn and the fiberglass is exposed or frayed, that would be a concern in my book. Also, apparently, they had no concerns about driving fasteners through the material, which I find problematic, regardless of the roof covering material.
The home was built in 1960
I agree. I was surprised that there were no moisture stains on the ceiling inside.
I am surprised as well. But water is a funny thing, and it could be slowly saturating and degrading the substrate, trapped between materials.
Agree… and my first thought was… are you sure this is an actual “covering”, and NOT an underlayment acting as a cover material? Were you able to deterine the thickness of the material?
I was not, but after you mentioned it, it does look like an underlayment.
Was this the only location this material was placed? What was applied to the rest of the structure?
Am I correct that this “deck” was built on top of a pre-existing roof, after the original construction date of build?
Yes, this was the only location where this material was found. The rest of the home has 3-tab shingles.
As far as I can determine at this point, yes.
This, in and of itself, would be a RED FLAG to the (homeowner) taking the cheapest way out. IMO, it also shoots down the GRP theory due to the expense for such a small area, and potential damage from the weight and movement of the (loaded) Deck!
It could also be moving/flowing to a location that’s hidden behind wall finishes before gravity takes it to a lower level. Was any water intrusion observed anywhere else in the home? Moisture has a way to travel distances away from where one would assume it to be located.
No signs of moisture intrusion anywhere else.
Joe, Hi!
Just out here curiosity, what brings you to the point of determining the materials that may have been used to build this particular flat roof? I personally have not seen anything similar! Have you considered asking the current owners of the property?
Pedro, my state SOP requires me to describe the roof covering type. I was not able to ask the current owner as they were not present for my inspection.
Never seen a roll or sheet that would not buckle under fasteners or hardware.
Fibrous roll roofing, commonly called mineral-surfaced roll roofing or (MSR) is a budget-friendly, roll membrane using fiberglass or ‘organic fibers’ soaked in asphalt and coated with ceramic granules or not. Designed primarily for low-slope utilitarian structures such as this, it served as a straightforward waterproofing.
I suspect it is a liquid applied atop metal roof decking.
Unknown roof deck material.
Refer to the venders or agents for disclosure.
Recommend a licensed roofing contractor assess the roof covering prior purchase due to, “Unknown roof deck material.” Act upon any recommendations therein.
