Maybe we can use them to heat water as that is the recommended temp.
Nothing greater than 100°F along entire length…end of this portion of the testing procedure…awaiting further Govt. funding to continue…
I agree with Greg’s post. The NEC does not distinguish about the temperature of the incandescent lighting. The Rope Lighting is UL listed as incandescent type of lighting. Even if it is plugged in.
that true but however i did spotted a LED verison of ropelight and that can change a bit with this.
- quick note ., i did not catch the manufacter name on this one but if i can catch it i will put in here so you can get some idea what it is]
Merci, Marc
