Originally Posted By: ccoombs This post was automatically imported from our archived forum.
Beams would fall under the L/240 range (L/360 based on load combinations). However, this is a structural requirement. There are many conditions were a beam is within the L/240 range and would be a problem. We not only limit deflection to L/240 (or similar limit) but also to an actual amount. Floor joist are limited to 1/2" and beams to 3/4" in living areas.
I agree with Robert. If you notice the deflection and it is a concern, it should be reported and referred to an engineer.
Originally Posted By: pbennett1 This post was automatically imported from our archived forum.
The beam deflects by about 1/4" in 43.5 inches due to removed foundation material which seems to be an ongoing building practice in NJ. I always call this out, especially when there are joists on top of the beam, and the buyer tells me they have plans of adding a second story.
