Sewer Scope Camera System
Need some good input. What is a good sewer scope camera system to start with? Also, what are some key “must have” features to be aware of? Pros and Cons if possible. Thanks in Advance.
This might help…
There are many threads on this in the archives of this forum.
Get training. A sewer scope is not just pushing a camera through a pipe. Training will tell you what you need to know about tools.
Become an InterNACHI® Certified Sewer Scope Inspector
Thanks for the info. Training has been completed, as well as facilities and utilities management for some time. I was just picking the brains for some advice on a smaller scale. Large utilities is what I am use to. Thanks in Advance.
Thanks Dave!
Rigid is the brand I see all the pros using. Even those break at times. There are lots of cheaper brands that aren’t as rugged. There’s a pretty big difference between running down newer plastic ABS/PVC lines and old cast iron, concrete or clay pipes. Over the years we’ve subbed out the scopes and I’ve watched thousands. I bought a Scout brand camera and have done a couple of my own and it works fine but I’d never put it down anything but a plastic line.
I’d definitely have a plan for what to do when your equipment goes down. Local repair availability? Backup to sub out the work to? Backup camera?
