A Navy shower should be fine. Save fresh water for drinking. It will be many, many years before we figure out (and agree to implement a plan on…) how to replenish our nation’s aquifers after decades of abuse and neglect.
This is an important subject for me down here in Texas. Especially with our population boom. Lawn irrigation really chaps my hide.
It’s amazing how many people are obtuse to the fresh water shortage/crisis. It is front of mind in my area because other states have tried to find ways to tap into our plentiful supply.
If it’s plentiful, why won’t you share?
If you read the bill, it regulates flow rate, not pressure… two very different things. If you read the news articles about it, it is clear that the journalists use the terms interchangeably. ![]()
You can run your showers at as much pressure as you want. Just keep it under 2.5 gpm, which is more than enough.
H.R. 4593, the SHOWER Act—Rep. Fry (SC-07)
- The Energy Policy and Conservation Act (EPCA) defines “showerhead” broadly and, under current law, allows the maximum water use for any showerhead to be 2.5 gallons per minute (GPM) when measured at a flowing water pressure of 80 pounds per square inch.
Not to make light of it but I immediately thought of this.
I spend some time in Maui and water usage is a BIG thing there. Golf courses really battle to stay green. Up in West Maui the PGA Kapalua tournament was cancelled this year because of it.
We have plenty of water. Our water is mostly sourced from rivers. The water is fresh and soft. I irrigate my lawn every other day in the summer.
This is why I moved away from the southwest. I have concerns about the water shortages and I’m not buying a $800,000 house in a region that may dry up.
