shrinkage cracks
Originally Posted By: jlybolt
http://www.nachi.org/bbsystem/usrimages/1/spalling.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/shrinkagecracks.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/cracks.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/crack.JPG ]
Originally Posted By: mboyett
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
Originally Posted By: mcyr
James,
Cement parging of the concrete surface is in no doubt in my mind.
Excessive drying is in fact the contributor to the shrinkage.
More pronounced when a cement coat is applied to a foundation for whatever reason.
Hope this helps.
Marcel
Originally Posted By: Mark Anderson
BUT–cracked-loose cement parging on a block wall will allow water to get into/enter through unprotected block exterior & joints,which then allows the possibilities/entryways for mold/efflorescence/radon gas `n insects. See this all the time here in Mich. Got milk? icon_smile.gif
Careful with that Axe Eugene...P.Floyd
Are you ready for some F O O T B A L L ???
The Real reasons basements leak
icon_smile.gif Who said anything about this being a block wall.?
Originally Posted By: tallen
It’s a crappy pour, but it looks ok to me.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Originally Posted By: rgallahorn
I agree with Michael, the first several don’t raise any hairs, but I would probably look a whole lot closer in the areas around the last pic before I gave up.
monolithic slab ] I’ve never seen or noticed the rigid insulation, I don’t think that’s done here at all. The ~1/8" cosmetic parge coat is applied directly to the rough slab to ‘dress it up’ some.
Mike Boyett
Austin, Tx
http://www.nachi.org/bbsystem/usrimages/1/.JPG ]
James;
Looking at one of the pictures again, it appears the the bed joint mortar on the right of the picture was installed indicative of after the parge coat.
To the left, it appears that the parge coat might have been done afterwards, because you can not see the bed joint for the brick.
Any idea on this one?
Marcel
Originally Posted By: rwand
I noticed there was garden hose in the first picture. My thinking is that the parging is wetted by the proximity or watering of grass. Parging will wick water hydrating parging and then drying out, causing spalling.
Question is your area of Texas prone to frost during winter months? If so the parging if wetted and freezing maybe the cause of the spalling.
Raymond Wand
Alton, ON
The value of experience is not in seeing much,
but in seeing wisely. - Sir William Osler 1905
http://www.raymondwand.ca
NACHI Member
Registered Home Inspector (R.H.I.)
Frost is not a big concern in this area. Raymond I think you have a good point. Most of the spalling was near the water spigots.
Yesterday went out to same job and reinspected slab. I came to the conclusion its was just spalling, shrinkage cracks and a piece of rebar that started to break through. Next time I will pay closer attention to detail but this post has helped me get a better feeling for foundations. Everyones help is really appreciated.
I am glad I joined this organization.
thankyou
James,
If you get a chance you might see if John Cahill is still offering his one-day foundation course. I took it a couple of months ago down in San Antonio and really got some good information from it. The class qualifies for 8 TREC CE hours also so that’s good too. The following link doesn’t indicate that the course is still available so you might have to call John’s office. Try: http://www.clearviewbsi.com/description.htm . John is a well respected HI in the Dallas area, a NACHI member, a long time member of the TREC Inspectors Subcommittee and also provides training classes around the state. Once you’ve taken the course SafeGuard CableLock company out of Houston will certify you to offer your clients a free 90 foundation warranty also. This may or may not be something you would be interested in.
Mike Boyett
Austin, Tx
Micheal, thanks for the information. It sounds like a good class to go to.
If I get any information on this class I will let everyone know.
