If you can smell it , it is a problem.
I used to run gas pipe everyday for Sears, and yes would check for leaks with a lighter , like a dummy.
Funny thing is I had a kitchen flare out on me one day when I went to move a stove to change the old flex and it was one of those old Brass recalled models.
All my hair was singed,as I should have blown out the damn pilots first.
Sometimes a spark is all it takes.
I was managing across the street from a whole block of houses that caught fire when a main suddenly had the pressure regulater give way.
The pilots flared like jets.
Gas is not a toy.
“always”
Every leak I find gets turned off, the seller, buyer and RE Agents are informed it needs immediate attention.
Robert,
Of course it’s not OK! And of course a leak is always a write-up. Bite my head off why don’t ya! The question was just do you or don’t you shut off the gas. Lets say - vacant house, freezing temps, and its a tiny leak outside. You shut off the gas and let all the plumbing freeze? I don’t. I leave the gas on, call someone who cares and tell them it needs immediate repair, and report the issue as “in need of repair”.
No sleeping children next to the leak. Talk about going overboard.
Is it normal and acceptable for a propane regulator to give off a bit of gas occasionally? This is a serious question, as I wouldn’t panic unless there was a strong smell in or under the house.
I guess my earlier post did not go through and it said…
Brian the Tiff is a great way to locate the exact point of a leak.
Andrew sorry if you took it the wrong way as I was addressing the subject and not slamming you.
No problem. In reality were probably about on the same page here. I agree that “if you can smell it, its a problem”.
jkogel - I pretty sure that a regulator should not give off any gas. My TIFF has gone off on them before and I write it up. I’m hoping someone with more certainty will reply on the matter.
I thought that was the reason propane bottles and regulators are kept outside - because they give off gas.
I replied sometimes because “always” leaves no room for the various situations we come across. If the house is vacant or no one is in attendance, by all means yes. If the seller is present, I inform them of my discovery and allow them to make the call. If the seller decides to turn it off, it doesn’t fit the “always” category. If the homeowner does not want it off for whatever the reason, I do not turn it off. That being said, I will not leave a significant safety hazard without all parties notified.
By the way, do you turn off electrical too if you see chaffed or brunt wires?
What if it’s a FSBO and there are no agents involved? Informing the buyer doesn’t mean a thing. If the home is vacant, how do you find and contact the seller? What if the seller is in France and you can’t reach them?
You’ve just shut off the heat to a home in the winter. Hope you have good insurance.
Playing devil’s advocate here. For those that “always” tun off the gas when you encounter a leak, I suppose you also…
- Turn off the main breaker when you find a house with aluminum wiring, especially if the house is occupied by helpless, adorable, little children.
- Unplug the refrigerator when you find out the outlet its plugged in to is missing a ground.
- Call the fire department when you find a defective or missing smoke detector.
- Turn off the water heater when you find a draft hood mis-aligned.
- Call the state health dept. when you find probable asbestos.
- Post hazard warning tape around a deck you consider unsafe.
- etc.
*]etc.
Yes it is natural. As the pressure is reduced by the regulator, any excess pressure (propane) is vented. Increased pressure downstream of the regulator is common, especially if it is cold outside. LP is liquid in the tank, it gets colder as it becomes a gas because it’s boiling point is very low. As the propane gas warms up it expands like anything else and increases the pressure in the lines, causing a small release.
Regulators are normally outside of the home. If/when they are located inside, the vent** MUST** be piped to the exterior of the structure.
There shouldn’t be any propane present in or under a home. (outside of the lines and appliances, of course) If the regulator is vented inside the home or to the crawl, it is dead wrong.
10-3 = 1 cc/hour (a cc an hour is bubble tight and can be seen with soapy water)
10-4 = 1 cc/3 hours
These are roughly the acceptable leak rates for gas lines with threaded fittings.
I think a tiff might detect into this range
10-5 = 1 cc in 24 hours
10-6 = 1 cc/2 weeks
Be careful telling someone there are no leaks, no detectable leaks is a better way to say it.
http://www.hivacspecialists.com/leakage.html
http://seniordesign.engr.uidaho.edu/2003_2004/leaksforweeks/testing.htm
[FONT=Arial]
[/FONT][/FONT]http://www.amgas.com/ldrefpage.htm
Science is fun ![]()
Jon, Joe F, and Brian…
My thoughts exactly.
Despite what anyone thinks, we have no legal authority nor duty to simply turn off the gas to a dwelling.
No, we have no AUTHORITY, as we are not a public official nor do we work for (or are indemnified) by a public utility.
We have no DUTY to turn off the gas, In fact, many could argue that our only DUTY is to NOTIFY a person who either represents the owner or the authorities.
If we SHUT OFF the gas to a dwelling, when the connection to a gas dryer is leaking (as opposed to simply shutting off the gas to the dryer, if we are so inclined), and the occupant catches pneumonia and DIES as a result, because he/she simply does not have the money to pay for a repair on a weekend, we have overstepped our boundaries as HOME INSPECTORS.
We can, and should, notify the proper parties, especially if the occupant complains of smelling gas.
Once we state, for the record, that we have a legal and ethical DUTY to ACT, then Joe Funderburk raises the larger spectre:
WHERE DOES IT STOP?
Beyond that, science and reality play and important role in all of this, as well.
Do we call the police when we dont see working carbon monoxide and smoke detectors in the home? Why not shut the gas off then, as well?
Far more people perish each year as a result of both than seen from a minor gas leak.
When I went through home inspector training in the dark ages, we were taught to call the authorities if we suspected a gas leak, period. We were further instructed to vacate the home and call the fire dept. because they were fully educated upon how to best deal with the issue.
I know that when I inspected in VA, the gas company would be out immediately if a leak was suspected, as well as the FD.
Explosion levels Belleville home
05/02/2008
A man was seriously hurt early today when an apparent natural gas explosion leveled his home in Belleville.
A fire investigator makes his way through the rubble of a home at 1313 Orchard Street early today. The home was leveled in an apparent natural gas explosion about 4:30 a.m. in Belleville.
This, I believe, is a gas leak thread, not a gas expolsion thread Chris. ![]()
Wow, what an argument. There are some real teeth in this one if you ask me.
My point exactly.
Andrew that is not playing Devils Advocate.
That is playing sarcasim card in light of a logical answer.:twisted:
You gotta be carefull tossing around that word ,on the same thread as the inventor of Devils Advocate.
You know of all the groups I’ve worked with I expected this one to show signs of common sense.
If the leak is barely detectable and it is -2 degrees outside then I don’t turn the heat off. Talk about a liability. :roll:
HEADLINE - DAYTON DAILY NEWS - IDIOT HOME INSPECTOR CAUSES CHILDREN TO FREEZE
I would try to isolate the area and shut off that branch. I would attempt to minimize the danger to the inhabitants above all else.
