Gas Leaks
Originally Posted By: pdickerson
How may inspectors out there check for gas leaks. I know it is beyond the SOP, but I use a meter to check for leaks at every home I inspect that has gas. The other day I found 5 gas leaks in one home. That was a record for me. BTW, the seller was quite upset with me for turning off the gas to the leaking equipment. icon_rolleyes.gif
Originally Posted By: gbeaumont
Hi to all,
Paul, please don't take this as insulting, I post it as a warning to our members only.
Please ensure that if you are checking for gas leaks using a Tiff 8800 or similar, that it is properly calibrated and that you are not picking up readings from other VOC's, the gas sniffers are a good idicator, but do come up with a lot of false readings if used improperly.
I can set up a Tiff 8800 to go of if you are off gasing from to much beer last night, if you know what I mean ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Reagrds
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
Originally Posted By: wdecker
What I usually do, if I get a reading, is to double check the area with my nose. If I can’t smell it, I don’t write it up.
Hope this helps.
Will Decker
Decker Home Services
Skokie, IL 60076
[email protected]
Originally Posted By: bkelly2
wdecker wrote:
What I usually do, if I get a reading, is to double check the area with my nose. If I can't smell it, I don't write it up.
Hope this helps.
Then why the meter Will?
"I used to be disgusted, Now I try to Be amused"-Elvis Costello
Helps me to keep the sniffing down to a minimum.
![icon_cool.gif](upload://oPnLkqdJc33Dyf2uA3TQwRkfhwd.gif)
Will Decker
Skokie, IL 60076
[email protected]
Originally Posted By: bemelander
I do it the other way around. If I smell gas I use my Tiff meter to locate the leak. I have had some false readings from my tiff so it stays in the bag unless I smell gas.
Bill
Anchor Home Inspections
[email protected]
Gerry,
I could have used your advice a year ago. On one occasion, I measured a slight reading with my gas meter, and I also smelled a faint gas odor. I recommended repairs by the gas company. They came out and found nothing. I was lucky enough to be in the neighborhood. I met the gas company tech at the home. I showed him the leak that my meter and my nose picked up. He insisted that he could not smell it, and his meter did not pick it up. He also produced a document that stated there is an acceptable leak rate in the industry. He also held his lighter up to the pipe in question to prove to me that there was no leak. It was an educational day to say the least.
I have come to know my gas meter very well. It responds to lots of things besides gas, including temperature changes. I will not report a gas leak if I can't smell it. There are lots of things you can teach in a classroom, but I have learned that effectively reporting on gas leaks requires hands on experience.
Paul, everything leaks, every system has acceptable leak rates. The trick then becomes knowing the leak rates and the best way to validate the leak rates.
I believe in using my nose and falling back on soapy water. I believe the gas meters are too sensetive and will get one into more trouble than not.
Will that was very funny ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Originally Posted By: kshepard
Bacharach Leakator ll. Kept calibrated, appears to go off when around the colors white or brown or when someone within 10 ft uses improper grammar or thinks about sex.
I’m with Bill.
Kent
Originally Posted By: lkage
Bill
I like the nose first method too...mine, the clients, their dads, the realtors, etc. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Reagrds
Gerry
Hay Gerry. i want a "fart-o-meter" in my tool bag too.... ![icon_cool.gif](upload://oPnLkqdJc33Dyf2uA3TQwRkfhwd.gif)
Originally Posted By: dvalley
If you can’t smell gas in a home, leave the TIFF in your tool bag.
If I were to break out my TIFF in every home I inspect, I will find a leak (whether it be minute or major) in every home.
Most Gas Valves, regulators and pipe threads do leak (very minor) and the TIFF will pick them up. So unless you want to look bad in front of plumbers on a daily basis, use your nose. I utilize my TIFF strictly to locate a gas leak only when I smell it.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: dspencer
…and how professional does it look when a client sees you putting your nose up to all the fittings??? Did you goto school for that?
I use meter, then my liquid gas leak kit comes out next.
Originally Posted By: rwashington
Paul,
Do you have a reference for that document that the gas company provided? I would like to learn more about the acceptable amount of leakage?
Richard attached is a gas piping spec. Pressure test 10 minutes @ 3 psig wih no pressure drop.
http://co.pinal.az.us/building_safety/files/009Gaspipe.pdf
This is a fun leak rate page
http://www.futuretechnologies.com/PrDecay.htm
Richard,
I did not receive a copy of the document. I will do a little research and see if I can find the info.
US and Canadian standards allow a maximum leak rate at most gas appliances of 235 cc/hour at internal valves and controls, and 200 cc/hour external. This correlates to 12 BTU’s per hour of propane. I believe the ANSI standard is Z21/83.
I was not able to locate the standards, but I found a presentation of the safety standards by Frank Stanonik at the Gas Appliance Manufacturers Association. The presentation can be found at the link below.
http://www.mac.doc.gov/china/Breakout%20C%20-%20Stanonik.pdf
If I were the client and I saw you If putting your nose right up to the gas fittings, I'd probably laugh my as$ off.
No one stated that you had to put your nose right next to the fittings. I simply stated that if you can't smell gas (within the home) to leave your TIFF in your tool bag. A gas leak will smell without placing your nose up against all the pipes and fittings.
David Valley
MAB Member
Originally Posted By: mboyett
Paul, so how is that standard usable to the HI? How can I measure 200 cc/hr?
Michael,
No need to measure maximum leak rates. You'll be wasting your time.
If you smell gas, locate the leak with your gas detector and note it in the report.
If the gas smell is excessive...Stop the inspection, and get everyone out of the house. Then call the fire dept. from outside.
David Valley
MAB Member
