Hi all- Newbie here completing InterNACHI’s traing and trying to soak all the great information in. I am a registered Professional Engineer and have seen a lot of different things. HVAC being my background and growing up around construction. Something I was thinking about was if anyone has a siding identification “cheat sheet” if you will. Something that summarizes, maybe with pictures, all of the major types of siding and their most identifiable attribute. Most are easily identifiable but sometimes you might run across one that you wish you had a cheat sheet in your truck??? Thoughts?
Mentoring with other Homies will do more for you then all the sheets in the world .
You will have the info in your head and will be much better off .
http://www.calfinder.com/library/siding/types-of-siding
http://architecture.about.com/od/buildyourhous1/tp/siding.htm
http://www.home-style-choices.com/house-siding-types.html
http://www.sidingsolutions.com/pages/sidingid.htm
Thanks for the links Larry!
