How can you tell the size ? and is that
critical to a good inspection.
David
Pyramid Home Inspections
David
The model number of the unit and compressor.
It gives you worthless information unless you know what you are doing with it. It has nothing to do with home inspection.
David,
I usually list the Unit(s) model #, which indicates the capacity. I don’t comment of the sizing for the area served, because that falls outside our perview of H/I. It’s good information for the Client.
DN,
This depends on the question(s) being asked of you.
The most common around here are “How many tons do I have?”, “How old is it?”, or “Is this unit efficient?” All are fairly easy to answer but do not tell the story about the installed system.
Not all systems are matched size condensing unit and evaporator coil, but all should be run through a program to calculate the many variables.
Sizing info, http://www.eere.energy.gov/consumer/your_home/space_heating_cooling/index.cfm/mytopic=12340
Preston Guide
http://www.prestonguide.com/
to elaborate, they’re is usually a number divisible by 12 in the model number.
24 - 2 ton
30 - 2.5 ton
36 - 3 ton
40 - 3.5 ton
etc, etc.
this # indicates the size ( tonnage ) of the unit, but nothing else.
I always point out the tonnage in my report, but never elaborate on its adequacy in respect to the home…just report on it’s performance the day of the inspection.
My state’s SOP requires me to report the BTUs, if available.
I list model, serial, tons, btus and age as a service to my client. I’m not required to do it.
I agree there is not much an HI can do with the size of the system/units, but many do like to report that info just for their clients information.
Some use rough area/ton numbers from local HVAC specialists (they vary greatly depending on the region you are in) to see if the system is in the “ball park” … but never comment on adequacy of the system. There are way to many variables, and even contractors that use area/ton rules of thumb as a guide to check their calcs adjust those numbers for site specific conditions (ceiling heights, windows/glass, exposure, insulation, tight construction, etc).
However on the other side of the coin, if you do report the size and it’s not adequate, the client may later ask why you didn’t report that (even though thats beyond the scope of a home inspection … but they don’t know that).
If you do include the size of systems in your reports, I recommend you make it clear that it’s for the clients information only, and determining the adequacy of the system is beyond your scope.
JMO & 2-nickels … ![]()
thanks, get well from your cancer…
