----- Original Message ----- From: rmjl To:FastReply@nachi.org Sent: Tuesday, January 03, 2006 9:51 PM Subject: Foundation/Sill Plate question
Hello; I’m trying to find out if it is recommended to use pressure treated sill plates (as opposed to plain wood 2x6) when using ICF basement foundation walls. Our sub-contractor claims it is not necessary, but the specs. call for it. I’d appreciate any help you could give me!
rcloyd
(Russell Cloyd, KY LIC #166164, IN LIC#HI02300068)
2
Martha,
Per the 2003 International Residential Code section R319.1: an approved, pressure treated lumber must be used -#2 All wood framing members that rest on concrete or masonry exterior foundation walls and are less than 8 inches from the exposed ground.
Best Regards
Russell Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
Does this meen that on a house that has a walkout basement with 2½ sides of the house that are 2 story (ranch house + basement) block or pored basement walls, would only need treated lumber on the 1½ or 2 sides that have earth against them?
