Originally Posted By: jbehling This post was automatically imported from our archived forum.
Sec. 2317.4. Plates, Sills and Sleepers. All foundation plates or sills and sleepers on a concrete or masonry slab, which is in direct contact with the earth, and sills which rest on concrete or masonry foundations, shall be treated wood or Foundation redwood, all marked or branded by an approved agency.
Additional Local Requirements: Exterior wall sill plates bearing on concrete must be Foundation redwood or pressure treated lumber and must be nominal 2 inch thickness (2x material) with their width at least equal to the width of studs to be used. Steel bolts used for sill anchorage shall be at least 10 inches long.
Ya, what Jeff said
Originally Posted By: dbroad This post was automatically imported from our archived forum.
It also depends on weather ist a barring wall and the sheer value as well. I am building a house and some sill plates are 3x6 due to sheer value as all walls in my house are 6". Some sill plates are 1 1/2" and some are 3".
Quote:
IRC R404.3 Wood sill plates.
Wood sill plates shall be a minimum of 2-inch by 4-inch (51 mm by 102 mm) nominal lumber. Sill plate anchorage shall be in accordance with Sections R403.1.6 and R602.11.
Quote:
IRC R602.3.4 Bottom (sole) plate.
Studs shall have full bearing on a nominal 2 by (38 mm) or larger plate or sill having a width at least equal to the width of the studs.
That is just a minimum to check as a guide.
-- Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Quote:
IRC R403.1.6 Foundation anchorage.
... The wood sole plate at exterior walls on monolithic slabs and wood sill plate shall be anchored to the foundation with anchor bolts spaced a maximum of 6 feet on center ... There shall be a minimum of two bolts per plate section with one bolt located not more than 12 inches or less than seven bolt diameters from each end of the plate section ... Bolts shall be at least 1/2 inch in diameter and shall extend a minimum of 7 inches into masonry or concrete ...
Note that those requirements are just the typical minimums, and additional anchors would be required in higher seismic/wind load regions.
[I added the spacing]
Eagle Engineering ?
