You guys ever see something like this? Expansion tank overflow pan is a literal cooking pan, fitted with a PVC drain that discharges into the water heater’s overflow pan. The whole thing is held onto the unit with gorilla tape.
My boss says that although it is an unusual installation method, there isnt anything wrong with it code-wise.
You may say the pan under the expansion tank is not required. The proximity of the plastic pan to the draft hood is not recommended and should be removed.
Also recommend the expansion tank be supported by other than piping material.
If the expansion tank is leaking from the air valve, the bladder has failed and the tank needs replaced, if it’s leaking at the pipe connection point, which I’ve seen due to dissimilar metal corrosion, the tank needs replaced.
There is no reason to have a cookie sheet with a drain pipe affixed to the tank in that manner.
My guess is that in the past, the homeowner probably had an expansion tank leak and do damage. This just makes this homeowner sleep better at night…just one less thing to fret over. (there are people like that).
I’m new here; it looks like the TPRV is terminated thru a wall, and does the pan also terminate thru the wall? I was under the impression that they had to terminate at least 6" from a drain and not thru a wall or floor
