This is a sub panel in a detached garage, which I am not real familiar with. It looks like the ground for this panel comes from the dwelling with the conductors. There is no ground rod outside on the garage. Am I correct that this panel should have its own ground rod, separate from the dwelling. Also there is a ground wire on the neutral bus. I have read this is incorrect on a sub panel. Would it be allowed if this panel has its own ground rod?
Thanks in advance for any insight
