Support for TJI joists & microllam?
The microllam was supported by one 2x6 & on the opposite side by two 2x4’s? Is that enough? I would think at least two 2x6’s and three 2x4’s with that size beam.
The triple joists are supported by one 2x10 and then on the other side by one 2x6 & one 2x4. This also looks insufficient.
T-post configurations are pretty strong plus you have a double top plate…however I would refer to the blue print and/or the Ijoist installation instructions.
On a side note, I am not a fan of styrofoam sheathing as it add not structural value to a wall system… is this a phased inspection you’re doing or just stopped by a jobsite to check it out?
Jeff
phased inspection. the styrofoam is common around here.
I don’t dare comment on it being wrong as I don’t know what the difference is between a 2x4 and a 2x6.:shock::shock::shock:
About time you began to wise up! :wink:
