Saw one of these units installed today. I noted both the unit was not secured to the cabinet and it was double tapped to an existing breaker. Turns out, UL has also published this unit is a potential fire hazard. Would you/have you informed the sellers about this component? Why/why not?
Details on the install below:
Note, this unit was included in an update to the article in 2019.
Unit must be secured and connected with the shortest lead wires possible and not be double-tapped. If UL says it is a fire hazard, I would definitely call it out and recommend removal.
