It is hard to see in these pictures, but just below the end of the shadow there is a “buckle” on the roofing. I could not get into the attic because the scuttle hole was closed off.
How would you guys call this out? Curious as to your ideas.
there appears to be something going on in terms of settlement as indicated by the apparent seperation/settlement between the vent pipes and their flashings (if I am seeing that right)
Certainly needs further evaluation from inside the roof space.
I have to satisfy your curiosity now :-). The scuttle hole was closed off, they actually sprayed texture over it! The whole garage was textured with “popcorn ceiling”…walls and all!
Very common here. I cut the edge free with a knife (with permision if possible) and push it up. Just too important not to see the attic from my perspecive. Of course you where there and it may have been secured with more than just popcorn spray. It’s your call.
It didn’t appear to just have been sprayed. The scuttle hole was too smooth and you could not even see the lines where it was. In this case there was no way I was going to push on this and get a nice fat repair bill.
“The roof sheathing appears to have a dip or sag. Visible sags or defects in the roof framing were not visible because the attic was inaccessible. We can elaborate on the possible reasons for this, but you should have a roofing contractor evaluate the roof or comment on this specific feature.”
If the owners were there I carry a release form where I hand write what I’m going to cut open. Printed is what could happen and that the accesses are there for a reason & should be left accessable. Pics look as if it may be 7/16" decking on 2’ centers, slight wave in roof. I’d say without getting in attic truss cord is bowed.
Thanks to all of you for answering my post!
Anthony, there was adequate ventilation providing the soffit vents were not blocked. But I could not tell not having access.
Thanks to all of you.
