Buying my first imager. Looking at mileseey 256c. $400.
Anything I am missing at this price point?
I think there is silence from the peanut gallery because most of us use either FLIR, FLUKE or HK MICRO. It will be interesting to see if someone has experience using MILESEEY and perhaps how it compares to more familiar brands. If you use the search bar, you will find plenty of previous discussions on various brands.
It kinda depends on what you’re going to do with it. If you’re just using it to verify moisture leaks and register temps it will probably work fine.
If you plan to do serious thermal imaging work it’s probably not up to the task.
Morning, Chard. Hope to find you well.
When it comes to Thermal imaging, I found new home inspectors wanting to get into thermal imaging skipped educational, and drove to price.
As for Meleseey Tools Infrared Thermal Imaging Cameras. (NETD≤40mk), TR20 series boasts an impressive 320 × 240 (76,800 pixels) thermal resolution, offering crisp thermal clarity with vivid details but I have never operated one.
Remember you will eventually require parts, maintenance and servicing.
Be sure when you purchase a thermal camera you have a service representative close to you.
1: Take a course. Thermal imaging is definitely helpful in finding defects that are not visibly apparent to the naked eye.
2: Be careful how you narrate defects and deficiencies and insure you reach out to your insurance what coverage you need.
Have you ever taken a thermal imaging class? Not just Internachi but a real certification class?
Currently internachi. Just getting started with it.
Suggest taking the monroe thermo imaging class and get the first certification, dont buy anything until you go through this class.
You will have to pay for the class but it is worth it.
Doing internachi right now. I’m just aiming to enhance basic inspections for now. Work my way up to the big stuff.
Unfortunately, no matter what you do is the “big stuff”.
You cannot turn on a thermal camera put it in automatic mode, and have it tell you what is going on. The camera is a tool and like all tools you have to learn how to use it. If you have a hammer, you need to know which nails to use for the task at hand. There is a specific application for every thermal job you attempt. You must understand what you’re pointing the camera at and how it reacts to heat transfer, reflection and absorption to determine if it is a significant defect.
Your standard of practice as a new camera owner is to use the camera as a glorified flashlight. If you see something that doesn’t look right you need to put down the camera and do what you do as a home inspector and go investigate to see if it is a significant deficiency that falls under the purview of home inspection. If you see funny colors in the ceiling, go up in the attic and see what it is.
Do not put in your report what you think the anomaly is and a picture of it. If it’s wintertime and you see blue spots in the ceiling at the wall juncture for example, blue is not water all the time and neither is cold air.
However you must be knowledgeable of thermodynamics to determine if cold air is causing condensation which is water, and they are both the same color.
Is that blue spot a significant defect? Is cold air getting into the house or is it just cooling off the wall? Can you call it missing insulation that requires repair because it is significant? If you recommend the house be sealed up better , this can cause indoor air quality problems and hurt somebody we have to take ventilation into account , and the air has to come from somewhere. If you close up the leaks, you may have to start putting in mechanical ventilation equipment which is more expensive than heating cost . It takes further analysis outside of home inspection standards to make that determination.
This is your primary concern because if your client tears up the wall and there is nothing significant there, that’s on you.
So be careful when you start out. Building science thermography is more complicated than any other use for thermal imaging. Just be aware of this.
I’ve been a builder my whole life so I have that. I’m not someone with 0 knowledge.
Also I’m just adding it as an extra tool for now to learn it.
My question was about the tool itself…
David wrote 4 paragraphs to add context to your question. He is likely one of the top thermographers in the country with decades of experience. I have worked beside him and have seen this firsthand.
I’ll say this. In my opinion, $400 aint gonna cut it if you are serious about anything other than a glorified flashlight, hence his comments. This is rich with good information for the thousands of other inspectors reading this.
Now, when I took my Level 1 class, my little C5 was fine for understanding the basics.
I’m not going full thermography right now is the thing.
Just enhancing what I am already doing.
How do you plan to use this tool, exactly? For training? Or to incorporate it into your home inspection? Do you plan on qualitative thermography or quantitative thermography?
Education is key here as others have mentioned, once you have that, your question will be answered.
Having said that, IR imagers have come along way regarding affordability. The first imagers were very costly and bulky. Years ago some of the limited options became more affordable and some manufacturer’s used the same hardware, then up charged for software which “unleashed” the potential of the hardware (E4, E6 and E8 for instance).
Now there are many options available.
There are a ton of threads on this topic in the archives of this forum.
Good luck.
Well I won’t be charging extra until I become more knowledgeable.
Just helping me locate things to check further.
I finished internachi cert but it leaves me needing more before I charge for an ancillary inspection.
Every time someone mentions using a thermal camera to help identify anomalies during a home inspection, the purists (thermographers) on here jump all over them defending their turf saying that, if you do not have at least a Level I certification, or whatever, you should not even own a thermal camera. I get it. A ton of home inspectors are out there making dumb interpretation mistakes, sullying our collective reputation, while blissfully inducing liabilities for themselves and possibly raising insurance rates for everyone. I would like to counter that the InterNACHI courses DO cover all the necessary material, perhaps just not as rigorously as more formal courses. However, if you study hard, all the necessary concepts and practices are there to help you not make silly mistakes. And with that qualifier, a thermal camera can become an immensely valuable anomaly detection tool for a home inspector.
Just trying to find a way to use it now to help me grow. I’m still a career builder. It’s just a second opinion for now.
Thank you. I’m not finding much support here. I think i will refrain from reaching out in the future.
I see nothing but support. And through hard questions and commentary, we are having to piece together the answer to your question.
Let’s start over.
You are missing a lot. Your question is similar to asking, “Hey, what this difference between a Honda and a…what?”
So we begin by explaining a range of things in response to an open-ended question. Tons of information provided. Many things to consider. And you feel unsupported?
So here we go…
Here’s a clean side-by-side comparison of the FLIR C5 and the Mileseey TR256C (256C) (often referred to as 256×192 class Mileseey cameras):
| Feature | FLIR C5 | Mileseey 256C |
| Thermal resolution | 160 × 120 (19,200 px) | 256 × 192 (49,152 px) |
| Image enhancement | FLIR MSX (edge overlay from visual camera) | Fusion / AI image enhancement (varies by model) |
| Visible camera | 5 MP | Typically 2–5 MP (model dependent) |
| Temperature range | ~ -4°F to 752°F (-20°C to 400°C) | Similar range (~ -4°F to 1022°F depending on variant) |
| Accuracy | ±3°C or ±3% | Typically ±2°C or ±2% (varies by unit) |
| Display / interface | Built-in touchscreen, FLIR OS | Touchscreen or app-based (model dependent) |
| Connectivity | Wi-Fi, FLIR Ignite cloud upload | Wi-Fi + app transfer (no unified cloud ecosystem like FLIR) |
| Durability | IP54, 2 m drop tested | Usually IP54–IP65 (varies by model) |
| Form factor | Rugged pocket camera | Similar pocket-style or handheld |
| Battery life | ~4 hours | Often 3–6 hours (varies) |
| Reporting/software | Strong (FLIR Tools / Ignite ecosystem) | Basic-to-moderate reporting via app |
| Best strength | Workflow, reporting, reliability | Higher thermal resolution per dollar |
| Typical price range | Higher ($500–$700+) | Lower ($250–$500 range) |
FLIR C5 advantage:
Better inspection workflow (reports, cloud storage, stability, industry standardization)
Mileseey 256C advantage:
Better raw image detail because 256×192 has ~2× the thermal pixels
If you’re doing professional inspection reporting (home inspections, HVAC documentation, client reports) → FLIR C5
If you want maximum thermal detail for the money → Mileseey 256C
Yes. Claude and chat gpt do that for me. I was asking for real world info.
I think people assume I’m a typical rookie for sure.
30 plus years building houses.
