99.9% of home inspections are done for the buyer of the home. The buyer then addresses these issues with who ever it is that they are dealing with. That person then does as the Home Inspector suggested and calls in the appropriate licensed tradesman to evaluate the system in question. In this discussion it is about GFCI protection therefore an electrician.
Now the electrician is working for the seller or their agent and very seldom sees the Home Inspector’s report but instead is asked to do an evaluation of the system or to evaluate certain points of the system.
For the sake of this discussion let’s limit the evaluation to the outside receptacles.
The seller or their agent will ask the electrician to take a look at the receptacle and make a report.
The electrician goes out and checks the receptacle and its box and cover and everything looks okay. The electrician then reports back that the receptacle is fine except that it should have Ground Fault Protection.
The seller or their agent then asks if the receptacle is required to have Ground Fault Protection
The electrician then asks the date of the installation as this is very important to answer the question that was asked.
The seller or their agent says that the house was built in 1969 and the circuit is part of the original installation.
The electrician then advises that the receptacle is not required to have Ground Fault protection due to the installation date but suggest that it be. The seller then says that this receptacle has been this way from the day they moved into the house and they are not going to spend any money to have it changed.
Electrician says this is between the seller and buyer but he is not going to furnish his time and material for free so the electrician goes fishing.
The buyer decides to go ahead and buy the house with the receptacle as it is. The professional home inspector that he hired has spent time to make a report that there is a danger there. The buyer is fully aware due to the assiduousness of the Home Inspector that there is a danger with the receptacle not being protected by a ground fault device.
The electrician has made his effort to get the seller to change the device but the seller says that it was fine the way it is the whole time he lived there and if the buyer is not happy with it then let them come off with the price of having it changed.
Both the Home Inspector and the electrician has done all they can and the final burden lies in the hand of the buyer and seller.
The electrician is not mad at the Home inspector for pointing out the fact that there is no ground fault protection on the device. If anything he is grateful that he had a chance to make some money.
Why would the Home Inspector be mad at the electrician for it not being changed? It seems to me (an electrician) that some Home Inspectors think that I should change the device no matter if I am being paid or not just because they pointed it out.
If the Home Inspector points out the danger to the person that is buying the house and a year down the road someone gets hurt or killed it is my thinking that it is the buyers fault after they have been told of the danger by a Professional they hired.
Sorry I got a little long winded but I hope that my ranting helps you understand that I am not talking anyone out of anything. I am only doing what I am being paid to do.
