I saw this yesterday onsite.
Just curious on some feedback on the set up of this breaker. It seemed a little unusual to me so I am looking for some feedback.
I appreciate all the insights.
Thanks
Jonathan
Thanks
Jonathan
Just wrong is all i can say
Factory installed jumper to a split bus panel. Rather obsolete but that’s how they were manufactured, the load side of the CB feeding the lower section of bus.
search ***split bus FPE ***
fairly common down here…
Yep. Nothing to report with regard to the set up, however, it is a Federal Pacific Electric, Stablok load-center.
How are those wires affixed to the lower breaker holders…solder that can’t be seen or some sort of mechanical fastening system that can’t be seen?
It’s magic…
…or mastic. I can’t remember which.
In the past I’d see a “split-buss” on about 35-40% of any panel I opened.
Very common around here.
It’s a soldered connection…
I appreciate the feedback. It is indeed a Federal Pacific Stab-Lok, which I talked to the client about.
Once again, thanks all
Jonathan
