Anyone ever use these tablets (included in conservation kits in link) to find leaks between toilet tank and bowl? Do they work? Is this a common problem?
I simply grab a piece of toilet paper and swipe the outer seal area under the tank. Quick and easy.
I get down and shine my light they stand out easy to see with a good light .
… cookie
It’s a common enough problem that I do it on every toilet.
I get down ans shine my light as well on both sides. Sometimes there just isn’t enough room for me but I do my best.
I also do it right after I flush the unit as that’s when the seal is “exposed” to the water.
A little food coloring in the tank works as well if you have to have a dye.
Cheaper than tablets and you can have your choice of colors.
left over Black coffee or tea also works and it is free.
I find I do not need colour to see the leak.
… Cookie
You can get all the free dye tablets you want from Fluidmaster. Since they sell replacement toilet parts they are more that happy if you find a leak
I carry a bunch of thier tablets with me but I never use them.
Okay, Paul, I’ll bite…why do you carry them if you don’t use them?
I don’t see it coming but I’ll probably get hammered…![]()
Legitimate question Larry,
I guess my reasons are as follows;
- They are free.
- They take very little room in a crevase of the bottom of bag somewhere.
- I was going to use them and just couldn’t be bothered with the extra few seconds it would take
- Just in case the is a situation sometime where I wish I had them.
I suppose if you flushed enough of them you could do a septic dye test. A lot of them
but I don’t really like septic dye tests anyways.
They’re kind of like “Pop Rocks” which is fun, but they stain your teeth blue.
