mmaizel
(Marvin Maizel, CMI® Fl State Lic HI 681)
If you look closely, I hope you can see that the top chord extension is also being used as bearing. There is nothing suporting the truss joists on the bottom.
I am not used to seeing this method and wanted to see if anyone knows if truss joinsts can now be engineered this way.
mmaizel
4
Thanks for the responses…This is a tract builder and he does not have to give me the truss engineering. I could track down the truss builder and pass it by them, or possibly another designer… I have never seen this method approved so it is getting my attention.
Larry, you say that this is not uncommon?
Top hung trusses are very common in commercial construction. I have installed them numerous times. Plumbers and electicians love them as it is easy to install there water and wiring. Just make ure they have a continuos 2x4 or 2x6 on each upright between the webs.
I agree with Robert and Gregs comments on the design. The contractor does have to show the info but not to a HI. If you are on site for consulting you need another HAT so to speak.
