Thanks guys I am located in Michigan but will be taking my NHIE exam soon to be able to do inspections in Indiana also.
I just want to make sure and know what I am talking about and to be honest I still think either I dont get it or what I read in the training materials here is not clear.
A response on here says that 30" is optimal but I cut and paste where it says 30" is minimal right out of the NACHI training here.
A trap is designed to keep sewer gases and airborne bacteria from escaping the drainage system and entering the dwelling. Each plumbing fixture should be separately trapped by a water-seal trap, except as otherwise permitted by the plumbing standard. Fixtures such as water closets and urinals that have integral traps do not require an additional trap installed.
The vertical distance from the fixture outlet to the trap weir should not exceed 24 inches (610 mm). The vertical distance controls the drainage-flow velocity. If the trap has an excessively long vertical separation from the fixture, the velocity of the flow at the trap inlet can create siphoning.
The horizontal distance should not exceed 30 inches (610 mm), as measured from the center line of the fixture outlet to the center line of the inlet of the trap. The horizontal distance from a fixture to the trap limits the amount of bacterial growth and odor. It is desirable to locate the trap as close to the fixture as possible. A fixture should not be double-trapped.
Standpipes should be individually trapped. Standpipes, such as for a clothes washer, should have a minimum height above the trap of 18 inches (457 mm), and a maximum of 42 inches (1,066 mm). Access to all standpipes should be provided for cleaning and rodding.
I must confess I did not notice the horizontal T. I see now where it could back up into the standpipe. I shall lookout for this from now on, thank you Robert for pointing this out.
I got it from “25 Standards Every Inspector Should Know”
“Standard #14: Standpipes”
The first line is "Standpipes should extend at least 18 inches and no more than 42 inches above the trap weir. The standpipe should be at least 30 inches high measured from the crown weir. "
I am confused by the contradiction just like you are.
Maybe there is an error in the page of that particular page of “25 Standards Every Inspector Should Know” and the answer is in Robert Smoth’s quote “The horizontal distance should not exceed 30 inches (610 mm), as measured from the center line of the fixture outlet to the center line of the inlet of the trap. The horizontal distance from a fixture to the trap limits the amount of bacterial growth and odor. It is desirable to locate the trap as close to the fixture as possible. A fixture should not be double-trapped.”
So the 30" really refers to another part in the system.
I found the following
“The horizontal distance from the fixture outlet to the trap weir should not be greater than 30 inches, measured from the centerline of the fixture outlet to the centerline of the inlet of the trap”
on this page http://education.nachi.org/show.php?..6&course_id=54
Obviusly the contradiction mentioned earlier, is an error.
