Should this trap be called out on report as inproper S trap?
Thank you
TW
Yes, I would, I would also mention the flex connector as well.
You have your answer .
However what is your comment going to be …here is an generic comment from other NACHI members…
Edit it to suit your needs.
"1) There is at least one or more “unvented S-Trap(s)” present. Although common in older homes like this one, they have not been an approved use in plumbing systems for over 20 years. Sometimes they will gurgle when draining water (they’re struggling for air). They can also dry up and allow sewer gas or odors back into the building. Common methods of repair are properly venting them outside, or if that is not possible - changing any of them to a “P-trap” with an AAV (auto-vent) if your jurisdiction allows it. We recommend you consider changing these.
- There is at least one or more “unvented S-Trap(s)” present. Although common in older homes, this home is newer and in our opinion this indicates a handyman installation VERSUS performed by a competent plumber. These traps have not been an approved use in plumbing systems for at least 20+ years. Sometimes they will gurgle when draining water (they’re struggling for air). They can also dry up and allow sewer gas or odors back into the building. Common methods of repair are properly venting them outside, or if that is not possible - changing any of them to a “P-trap” with an AAV (auto-vent) if your jurisdiction allows it. We recommend having any of these replaced to conform to current plumbing standards.
What did your training at AHIT say, or teach you, about this?
Christopher Currins, CMI
Who are you talkin’ to?
