I came across this one today and am curious if anyone as seen this before or can help best identify the cause.
The building was built in the 1970s. Trusses have been used via the attached photos.
It was difficult to full encapsulate the bowing effect. Nearly 50% of the truss on the rear South side of the home have bow like the ones in the images.
With this being said, there is no evidence of active water penetration or staining. There is NO apparent structure damage and or cracking within the building either and the building is on a cement slab foundation.
Any input is well received, thanks and Happy FRIDAY !
I agree as well, would this strictly have happened only on the south of the Truss and at 50% affected ?
My other presumptiveness was thinking it may have been a wet to dry bowing , if the truss had been installed damp then dried to give the give bowing, either way, I think the further investigation by a structural engineer may be the best bet
but since the load is not being dispersed as per the the design, I would assume the @kleonard comment would still be the best way to report it.
with a side note of the your comment
things are just humming along here and ramping up yet again … we had a "slow period of about month or so after Christmas… going to be another full tilt year I believe… hows things on the Island ?
